Hey Carfanatic, sorry for your problems with the viffer, but was wondering if you ever used Seafoam while you had this bike? or Stabil? I use Seafoam regulary and it cleans gum and keeps fuel line and injectors clean/clear! It might help out with your clogged injector??? Worth a try I think:rockon:
Still working on the bike. Sent the injectors out for cleaning and reassembled the bike but now it won't run for more than 5 seconds before dying. If I give it any throttle it dies immediately. The FI light is signaling a fault IAT sensor but that shouldn't be causing these issues I would think. I am going to strip it back down and make sure I didn't miss anything and reassemble to see if I can get it running. It is running on all 4 cylinders though when I start it up and the idle sounds good when it does idle.
Try taking the VFRness out. Tightwad and I were never able to make it work on my 2003, and it behaved the same way...
