VFR750FT Headlights shining in the wrong direction for driving on the left
Discussion in '3rd & 4th Generation 1990-1997' started by simonRC36RC46, Oct 3, 2011.
  1. simonRC36RC46
    simonRC36RC46 New Member
    My RC36 has headlights for a right side drive country and I live in a left side drive country so they won't pass it through the test. Can anyone tell me how to make the lights shine the other way - to the left instead of to the right
  2. Bryan88
    South Africa
    Durban, South Africa
    That sucks! Fortunately the gut who inspected my bike didn't notice that. Good luck man.
  3. mph
    mph New Member
    NM
    Aren't there knobs to aim it on the back of the housing?
  4. actungbaby
    actungbaby New Member
    Think your have to buy another headlight
  5. skimad4x4
    France
    French Alps & London
    - Correct if you want to do it right.
    The bodge is to simply lower the headlight aim so it wont affect other road users. Consult bike manual for location of adjusters - measure headlight centre height (with a rider on the bike), then mark that height on a wall - move bike so its 20 feet in front of a wall lower beam aim so the bright bit is a couple of inches below the line. That should work for beam test and inspection kit but won't if they check the lens certification stamps. It will also make your headlights far less effective if you need to ride at night - hence buying a used lhd unit is probably the right answer.
    Skimad4x4
    Proud Member 6th Gen Militia #218 - European 1st Division
  6. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    Opps sorry,
    Made unapplicable comment as I did't look at the Gen this post was in.
  7. squirrelman
    Your proceedure seems to correspond to mine with one important difference: the brightest spot of light should be 2" below horizontal WITH THE HIGH BEAM, not low. After the high beam is proppaly adjusted, the low is correct too. Laws in various contries may call for certain variations.
    Gen 4 bikes have a 2 identical heaDlights as far as i know, so nothing new would be required to re-aim using the adjustment knobs.
