vf500f rebuild
Discussion in '1st & 2nd Generation 1983-1989' started by V-FOUR, Jan 28, 2012.
  1. invisible cities
    invisible cities New Member
    new york
    About right, ;-)
    The FSM notes the intervals.
  2. Porkchop
    Porkchop New Member
    Worthington, Ohio, United States
    Wow... the rise in the rear end after the shock coversion is huge. There is daylight there!
    Does anybody know is that somewhere near factory stock height before all the stockers started sagging??? Or higher?
  3. V4JOHN
    V4JOHN New Member
    Wirral Penisular
    Whats with the exhaust silencers being capped off there, is that some legislation on emissions or something.
    Looking good though nicely done. I would have thought that the increase in rear ride height would massively increase the steering speed, which is already pretty quick.
  4. Mobtown
    Mobtown New Member
    Baltimore, MD
    They are not capped...they are trapped. SuperTrapped SuperTrapp: Performance Exhaust
  5. V-FOUR
    V-FOUR New Member
    I think I need to make the kick stand longer... It leans over too far imo, will another type of kick stand from honda fit? any ideas?
  6. V-FOUR
    V-FOUR New Member
    its higher then factory for sure, i had to remove my center stand because it was a half inch off the ground.
  7. smoke4ndmears
    smoke4ndmears New Member
    Maryland
    How does it handle now?
  8. V-FOUR
    V-FOUR New Member
    Much better, very easy turn in and very stable in the corners. Only woe is the kickstand and the sticky clutch when its cold, but for a 28 year old bike thats not too bad.
