VF500 F2 Rear Wheel Impossible!
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Sep 22, 2009.
Thread Status:
Not open for further replies.
  1. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I don't know, that's why I was suggesting that you check it!
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    So I went home on my lunch....pads seem to be in position....and they move freely.
    The caliper bracket doesn't sit perfectly straight compared to the rotor. I can't see why it's sitting like this when the spacers are tight with the swingarm....and the rotor isn't rubbing anything but the pads.
    Also noticed another thing:
    ^^ That's how close the center stand is to the tire. One more reason to yank it off. :rolleyes:
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    the center stand has alot of free play in it i would just remove it before it starts rubbing the tires which might cause a worse situation
  4. JamieDaugherty
    Fort Wayne, IN
    That's sounds like the problem with the swingarm casting I mentioned previously. You might try checking to see how the bracket fits in that tab on the swingarm. Let me know what you find out.
    Of course, none of my bikes have a center stand so this was not part of the design!
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    I popped the center stand off....so that's one less problem to worry about.
    I haven't had any chance to look at the brakes cause it's either night time or raining!!
    I did take the bike for a nice little jaunt and occasionally it feels a bit odd....some vibration....and an odd wobble at high speeds....enough to shake the handle bars if I'm not holding on to them. (I had my hands off them to check for vibration)
    Something about the bike feels wrong....kinda like it's not as stable as smooth as it was before
  6. JamieDaugherty
    Fort Wayne, IN
    Let's not forget that your rear ride height is lower now than stock. The wheel/tire is a big improvement but the lower ride height is affecting the front somewhat. The new shock coming your way will help that quite a bit.
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    Woot....new rear shock.
    ....I can install it without removing the rear wheel again.......rrrrrrrriight?
  8. JamieDaugherty
    Fort Wayne, IN
    Correct, the rear wheel does not need to be removed to install the shock.
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    Oh thank fuck.
  10. TRX250R
    TRX250R New Member
    R.I.
    So what can be done to the front to improve this. I ask cause when my bike goes in 4 the winter, I plan on the rear wheel swap. I already have, the rim and tire, just need to order the kit f/ you.
  11. slowbird
    slowbird Member
    Toronto, Ontario.
    I would also like to know.
    I have a spare set of forks I was either going to send to Jamie for some Gold valving and rebuilding....or take it somewhere local (or DIY) new springs, fork oil, fork seals, and dust boots.
  12. matt1986vf500f
    so how do you like the bike now?
  13. slowbird
    slowbird Member
    Toronto, Ontario.
    Who me?
    Well, like I mentioned earlier, the bike feels a little odd. Some vibration through the pegs at certain speeds....no rear brakes yet.
    ...and I get a really bad wobble when slowing down at a certain speed.
    It feels slightly unstable at slow speeds...like when crawling up to a red light.
  14. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    glad to see you got the wheel on. are you sure it is straight? Did they balance the rim when they put the new tire on?
  15. slowbird
    slowbird Member
    Toronto, Ontario.
    I have the chain adjusters set to the same notches on both sides.
    I put the bike on the rear stand and ran it in first gear and watched the tire and chain.....they seem straight to me.
    I also had a friend tail me in their car and watch my rear tire at 60km/h up to 130 km/h ......looked straight to them.
    What would a poorly aligned wheel feel like?
  16. matt1986vf500f
    like a bent frame!
  17. slowbird
    slowbird Member
    Toronto, Ontario.
    What does a bent frame feel like?
    (Don't say "Like a tire that is not aligned properly")
  18. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    If it isn't visibly off but still out of alignment I think you would only notice when you were cornering. Your handlebars would shake or wobble while in a turn
  19. slowbird
    slowbird Member
    Toronto, Ontario.
    My handle bars have never been completely smooth.
    Nothing really has changed except now when slowing down (Engine braking) the handle bars will get very wobbly at a certain speed.....I didn't notice until I let my hands off the grips ever so slightly.
  20. matt1986vf500f
    that could be from worn out steering stem bearings, you've change one part of the bike now everything else will feel different wait till you put the rear shock on it then it will change again!
Thread Status:
