VF500 F2 Rear Wheel Impossible!
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Sep 22, 2009.
Thread Status:
Not open for further replies.
  1. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    The VF500 and CBR cush drive are identical, so it doesn't matter. Normally I use the CBR ones, but only because they are usually in better shape.
    It might help to see the under side of the sprocket carrier to see if the spacer in there is seated all of the way.
    #61
  2. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    but his problem is he cant get the carrier to seat all the way.
    #62
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Tried this....no dice.
    Is it not something visabile in any of the pictures I posted earlier?
    UPDATE:
    I am unable to get the carrier any further in the wheel and everything still won't fit.
    These are pics with everything in...but without the right (last) Chain adjuster in.
    Also looks like the caliper bracket won't slide deeply into that little thing on the swingarm.
    This is all very frustrating and painful
    #63
  4. matt1986vf500f
    the rotor looks like its resting against the caliper bracket..like the wheel is cocked to one side or the other?
    do this try to take the crush drives out of the wheel ( only for testing purposes ) and see if the carrier sits all the way in then..
    #64
  5. matt1986vf500f
    #65
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    I tried the carrier without the Cush drive rubber bits and it still sticks out to far....and it seats on the center of the carrier somewhere.
    Tried a few hours longer with aid of a portable light...still won't fit.
    Why won't this carrier sit right? Pat said he had to pry open the swingarm to make this fit....I don't wanna install it like that.
    What's wrong that the carrier won't seat better?
    #66
  7. matt1986vf500f
    man i dont have a clue at this point wouldnt think it would be that big of a bitch to seat in there:confused:
    #67
  8. xtravbx
    xtravbx New Member
    Cleveland, OH
    So there has to be something on the carrier or the wheel that is touching before allowing them to seat flush enough. What is touching??
    #68
  9. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    I wouldn't say I had to "pry open my swingarm". I didn't have to exerpt a masive amount of force to get it in either; it just needed a guide because it maybe was off by 1/16th of an inch. I really didn't even have a lot of trouble with it.. i got it fixed up in probably 45min. I put good 1,000 mles on it too. No problems. If it was off by enough to actually bend the swingarm then it would have been alot more trouble to get in than it was.
    #69
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    I've tried putting everything on the axle and trying to slide everything in....no good.
    I've tried sliding the axle through the swing arm and through the wheel but still no good.
    I guess :confused:
    The inside of the carrier is that little bearing thing...and the rest of it sits on the rubber bits of the Cush drive.
    I tried squeezing the carrier tighter into the wheel with a rubber and plastic hand clamp thing and it doesn't stay tight!
    Sounds like my issue....alot of trouble.
    #70
  11. matt1986vf500f
    jamie step in here and tell us what could be the cause for this.
    #71
  12. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    At the risk of having my wrist slapped for trying to help - how about you two(Pcohen & slowbird) both measure the inside of your swingarms. Inside to inside at the very end of the arm would be best.
    Of course, this should be done with the wheel out, so that it can be measured properly.
    Matt, wouldn't hurt to get a dimension from you either.
    #72
  13. JamieDaugherty
    Fort Wayne, IN
    Correct - that's the problem.
    I think at this point it's fruitless to try and fit the wheel up until the sprocket carrier issue gets resolved. We know very well that it won't fit that way, as would be expected. I wouldn't bother measuring the swingarms as they don't vary in width that much. These are Hondas.
    Slowbird, can you get me a close-up of the inside of the sprocket carrier?
    #73
  14. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    It's simple process of elimination. What if a previous owner fubared his swingarm? With the mostly unknown history of a bike this old, who's to say it's still "as delivered from Honda"?
    Here's a pic slowbird posted on page 1 - close enough??
    #74
  15. slowbird
    slowbird Member
    Toronto, Ontario.
    Hey Jamie...let me know if the picture above is good or not or if you need anymore pictures.
    #75
  16. JamieDaugherty
    Fort Wayne, IN
    Not likely at all. I don't put much past that ability for a PO to hose something up, but the force it would take to compress a swingarm - and still allow the stock wheel to fit - is tremendous. I'd forget about that as it's not the problem.
    Ok, the inside of the sprocket carrier looks ok. What about the wheel itself? Something is keeping the carrier from fitting properly. I've never seen this happen before, so I'm hoping that it means it's something really obvious.
    #76
  17. slowbird
    slowbird Member
    Toronto, Ontario.
    #77
  18. matt1986vf500f
    i dont see anythign that would stop the carrier from going all the way in!? some one stop me and ell me i am wrong but i just dont see anything look like a normal F2 wheel
    #78
  19. slowbird
    slowbird Member
    Toronto, Ontario.
    When I removed the rubber bits of the cush-drive the Carrier seemed to seat on its center...not on any of the metal parts that go between the rubber bits.
    #79
  20. JamieDaugherty
    Fort Wayne, IN
    Well, about the only thing that stands out to me the surface where the carrier seats against. It's kind of hard to see in the pictures, but it looks like there might be something on it. I've circled it in the picture. I also included a picture of the carrier, I'm wondering if this mark is from something being pinched in there.
    #80
Thread Status:
