VF1000 carbs -- R vs F ??
Discussion in '1st & 2nd Generation 1983-1989' started by straycat, Oct 29, 2020.
  1. straycat
    Hey guys, the set of old carbs I took off the VF100oR I just did look different to the other 4 sets for VF1000R carbs I've taken off the otherVF1000R bikes. Im wondering if they are "F" carbs. Can you identify them ??
    The main difference is that the 4 sets of R carbs I have all have the carb bodies that attach via a bolt and tab, and they have what ill call a mental lug and tab setup swell, all to join and space the carbs properly. These other carbs I took off dont have that.
    There are no broken tabs or lugs on these mystery carbs.
    The numbers stamped into the carbs are also different
    I have 2 sets of carbs here for comparison
    First the known "R" carbs showing the bolted carb bodies, second the mystery carbs
    Another view of the inboard lug and tab. first pic is the "R" carbs see the tab and lug stop directly below the fuel line, second pic the mystery carbs, no tab & lug:
    Next the numbers stamped into the carb bodies
    R carbs first start with "85", mystery carbs second starts with "82"
    What do I have here "F" Carbs ?
    Since these mystery carbs are from the bike I just did and the bike came with a restored set of "R" carbs from Bill's, my suspicion is that a PO send the originals to billy's to be re-done and dropped a set of "F" carbs in in the mean-time and never got round to swapping the R's back in.
  2. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    VD82C VF1000FE Canada (Interceptor)
    SC150*EM000036 SC150*EM003908 SC15E-2000071 SC15E-2010931 VD82C A CANADA
    VF1000F2 a work in progress
  3. straycat
    thanks !, so they are VF1000 "F" interceptor carbs
    I guess ill be selling these, no use for them.
