Valve cover gasket
Discussion in '1st & 2nd Generation 1983-1989' started by MFTIC, Nov 8, 2016.
  1. MFTIC
    MFTIC New Member
    East of Seattle
    Very silly question....
    When i look at micro fiche the gasket has lobes (cam plugs?) on the gasket
    Whenever i look up the same part number elsewhere like on ebay and CMS those lobes are NOT on the gasket. I'm kinda confused as to what to order.
    *there was a little leak when i bought the bike that seems to have gone away. I'm afraid to check the valve's without having a set on hand in case things go wrong.
  2. Terry Smith
    I'm sure a VF500 specialist will pipe up soon (I only owned on for a year when they were new) but IIRC the later years had line-bored cam bearings and so needed the half moons on the gasket to plug the hole where the boring machine was used. The early ones had a flat face gasket. I'd make sure you are looking up parts for the correct year of manufacture. I see on Partzilla that 84 and 85 use the same part, 86 is different.
  3. MFTIC
    MFTIC New Member
    East of Seattle
    Thanks Terry. Went home and looked at the bike. Yes, it was a silly question. I can plainly see that it is just the flat gasket.
    Also the place i'm buying from gives a vin# range. I'll also look at that to double check. Gaskets are coming from Japan so I was a little worried.
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Yes the 86 has the ears as the 84/85 do not. The 86 has line bored cam journals the 84/85 doesn't.
