Trim clips
Discussion in 'Mechanics Garage' started by Sirdoh, Jan 24, 2020.
Tags:
  1. Sirdoh
    Sirdoh New Member
    Those crazy plastic trim clips that I've only seen on the VFR. Is there any reason why I couldn't use the common ones that have the round pin in the middle?
  2. KarlR
    KarlR New Member
    Esopus, NY
    No reason. I have some on my bike.
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    None whatsoever. The originals suck. If you want the screw type (1/4 turn to release), look up the ones for FJR1300 side panel/gas tank trim. Not cheap but work 90269-06081-00.
    The two at the fairing chin need to have a longer grip length due to going through two fairing pieces. All of these are 6mm dia.
