Tickover adjustment
Discussion in '5th Generation 1998-2001' started by Seriesman, Mar 9, 2021.
  1. Seriesman
    Seriesman New Member
    Scotland
    Hi folks 1998 gen 5 how is the tickover adjusted?
  2. Neill
    Neill New Member
    Just to the right of the chassis number (right hand beam frame, below the tank) there is a small hole may still have the original rubber bung in it. Open that up and use a small flat blade screwdriver to adjust the idle.
    Sent from my Pixel 4a (5G) using Tapatalk
  3. Seriesman
    Scotland
    excellent. thank you very much.
  4. squirrelman
    if you don't know, you need an owner's or service manual. :cool: lacking either you're seriously under educated.
  5. Seriesman
    Scotland
    Yes it is on the list.
    Only had the bike 14 days and spent that sorting the previous owners bodges and removing dodgy wiring and accessories!
    Wasnt sure if the tickover adjustment was a cable with a thumb screw and had been lost or removed .
  6. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    The correct tool for adjusting the idle screw on the 5th Gen is a JIS screwdriver (looks like a Phillips Head screwdriver but it's made to the Japanese Industrial Standard specification, which means it won't damage the JIS screw-heads on a Japanese motorcycle).
    An electronic copy of the 5th Gen Service Manual is available for free (it's either here on VFRWorld or over on VFRDiscussion, I can't remember which, maybe it's on both). You should get it.
    Setting the idle on a 5th Gen is something you do after you do the STARTER VALVE SYNCHONIZATION, which begins on page 5-67 of the Service Manual.
    Seriesman likes this.
  7. Seriesman
    Scotland
    Thanks i'll try find an electronic copy .
  8. raYzerman
    raYzerman Member
    Millgrove, ON
  9. Seriesman
    Scotland
    Thanks for that!
