synthetic motor oils
Discussion in '6th Generation 2002-2013' started by Guest, Jul 15, 2003.
  1. Guest
    Guest Guest
    Does anyone have any input on when (if ever) synthetic motor oil should be used? I have logged 4k miles, and it's time for the next change. I was wondering if I could use a synthetic, since the motors already broken in. I'm still not entirely trusting of the complex Vtec heads, and would like to protect them from wear.
  2. RedRocket800
    RedRocket800 New Member
    I would think that head wear is not a big issue, because 1/2 the valves are only used part time.
    I will say that at 6000 miles, I switched to Mobil 1 Vtwin oil.
  3. rshimmel
    rshimmel New Member
    Ventura, CA
    RR800- how many miles have you logged since the switch to Mobil 1 and how has the bike been running since then?
    Thanks.... Rick
  4. Guest
    Guest Guest
    The only reason I ask, is the Honda service dept. has advised to stay off the synthetic, because of the clutch. I guess there is (or could be) clutch slippage using the syntetic. Anyone had any experience with the above?
  5. tbtapper
    tbtapper New Member
    :)I have always used synth oils in my bikes. I have an 03 and swithched to Amsoil 10/40 at about 2,500mi.
    Never had any clutch slippage. Shifted better and I have personal knowledge of the superior wear protection afforded by syns. Not sure why Honda's stance but I recommend it.
    tbtapper
  6. jsmith811
    jsmith811 New Member
    London, Ky
    We use synthetic in the dirt bikes we race and have had zero issues with the clutch... as long as you use mobile One Red Cap that is. Some of the synthetic oils do have additives that are harmful to wet clutches. I'm not sure about the clutch on the VFR as I havn't purchased mine yet.
  7. Beast
    Beast New Member
    Valencia Spain
    At 4000mls the oil should be changed to the Honda recommended Semi Synthetic.
    Many of us here in the UK use fully Synthetic (including myself)..........your choice!
    What "you must" do is check that the words JASO MA appear on the can of oil as this indicates that the oil has the "lowest" slip index.
    Failure to do this "may well" cause your clutch to slip, but that has nothing to do with the oil being Synthetic or otherwise.
    If JASO MB is on the can the chances are that the clutch will not be happy.
    Brian
  8. Snafu
    Snafu New Member
    If anyone here is interested. I just bought several cases of Mobil 1 at Pepboys for $13 a case. You have to buy the Pepboys calender for a dollar so you can use the coupon. Buy 3qts get 3 free.
    I've been using Mobil 1 red cap for over 6k miles on my 03 with no issues.
  9. simple_guy
    simple_guy New Member
    Hey Ya'll,
    New to the forum here. I don't have the VFR yet by Saturday is coming. In regard to synthetic the reason the tech said stay away from synthetic is the XW-30W oils contain graphite, However, XW-40W and above does not. Basically the oils that have the "Conservation" additives. I will be using 5W-40 Rotella "T" 100% synthetic in mine. Depending on the performance of the clutch I may install performance springs to off set the lubricants quality. My 2 cents.
    jim
  10. KrautBurner
    KrautBurner New Member
    Bremerton, Wa
    I just did my 2nd oil change (@ 3500 mi)
    and under recomendation of the local motorcycle performance shop and the local honda shop, switched to amsoil full synthetic.
    they both recomended waiting till the 2nd oil change due to the clutch break in
    as well, said you can't use regular car synthetic, it dosn't have the friction modifier for the wet clutch.
    Russ
  11. mello dude
    Lots of miscellanous chatter here. Old style mechanix wisdom says break-in with petro oil for 8000-10000 mile and then switch to a synthetic if you are going to. I still do this. Synth is so slick, pistons and rings wont seat completely if you change too early. If they dont seat, you'll be burning oil for the bikes life. I dont want to risk it so I do the break-in miles with petro.
    -Honda has 2 semi-synths - 1 has moly in it and the other product does not. Stay away from the one with moly because of the clutch issues. The oil weight/viscosity rating has nothing to do with it. (XW-30W vs XW-40W - honda tech not too brite)
    - Modern motorcycle synth oils are all very good, for the VFR, you should stick to a 10w -40 rating and only use a 20w-50 if you live in very hot climate. The Mobile 1 V twin oil is 20w-50. There should be no clutch issues.
    - I use Mobil 1 Mx4t 10w-40. It was top rated in most testing situations by Sport Rider Magazine. Also I can buy it by the case at Pep Boyz and AutoZone.
    - I'm with KrautBurner - do not use car oil in a bike!
  12. M-Crew
    M-Crew New Member
    Brooklin on,Canada
    Ive been using Mobil 1 red cap(since has change to gold I think)15w-50.And have had no problems with it.Even up here in the Toronto area.
    Trust me you will see a vast improvement in shifting and overall proformance of your bike.It will run alittle warmer but only 1 to 2 c.With no clutch slippage.
    Go ahead and use it.You will be gald you did.:smile:
  13. daffy67
    daffy67 New Member
    I just had the 1000klm first service done on my new '05 and the dealer put in Castrol GPS full synthetic.
    They are doing all the warranty services until the warranty expires so if anything stuffs up then it's all back on them.
  14. M-Crew
    M-Crew New Member
    Brooklin on,Canada
    You have no worries as long as they are using a 10w-40 or more.
  15. daffy67
    daffy67 New Member
    It's 10w-50 i believe. :)
  16. RVFR
    Second oil change? Oh my I'd done like 6.. I'm a oil make sure is clean and good person. during those first miles like in the first 50 I'd changed it out then again at 300 then the service then at 1000, 2000 3000. yea I know for some it seems extreme, but it's my motor and I have prove what goes on inside, but yea new oils do last longer than they use to, but it's still cheap insurance as far as I'm concerned. There ya go, thats what I use, Amsoil great stuff, still change it every 2k.
