stage 3 air box mods
Discussion in 'Mechanics Garage' started by CandyRedRC46, Dec 16, 2012.
  1. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Have you ever opened up a fifth or sixth gen air box? All the(fresh cool air) is coming though a tiny gap between the gas tank and frame. The snorkel pulls air from much further away from this gap(the frame is blocked off and sealed up at the bottom with foam), then say an open air box like the one shown or simply a desnorkeled deflapped air box would.
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    So you still have the snorkel and flapper and stock filter in your bike?
    I can't dyno that exact lid because I have no way of getting my hands on it. But I'll post up my dyno running the following modifications:
    Motad headers
    Two brothers slip on
    BMC air filter
    Desnorkeled
    Deflappered
    Removed velocity stacks
    Throttle body entrances rounded off to mimic velocity stacks.
    All tuned on a dyno professionally with a pc3 usb
  3. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Here's factory
    The two layed over each other.
    And here's mine
  4. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    I have since traded the BMC for a piper cross filter and put r6 velocity stacks on.
    I should be getting a rapid bike 2 shortly and tuning all over again.
    And of course I will post the dyno as well.
  5. kennybobby
    kennybobby New Member
    Does the mixture change or something in the fuel injection cause that little dip in the torque curve from 6400 to 7200 rpm?
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    That is the vtec cross over point.
    It goes from 2 valves to 4 valves per cylinder at 6400 rpms.
  7. tinkerinWstuff
    Yes, stock box. K&N filter because of the re usability and not because I believe a clean K&N enhances engine performance over a clean OEM.
    When you do the dyno runs, you have to perform one mod at a time between each run in order to quantify if/what any changes result. Otherwise you're still just making assumptions.
    I've seen where a guy made changes to his bell mouths on the carbs and lost torque and HP. First rate work he did making the carb openings 2mm larger but lost performance measured on the dyno.
    Think about it - Honda is a sales organization there to make money. Target market is testosterone filled, midlife crisis types who like top performance and loud "look at me" machines. If a larger air filter or hole in the airbox provided a better customer experience, wouldn't they have shipped it that way? After all, we aren't talking about billet aluminum pistons or expensive titanium blingy bits - we're talking about free shit and we don't thing Honda's team of highly paid engineers wouldn't have discovered it?
  8. BereaVFR
    BereaVFR New Member
    Berea, KY
    The only thing that keeps me from fully buying your argument Tink is that we end users are not held to emissions standards and, depending on the end user, concerns about how longevity is affected. If they could do those things and not throw off either of those, then I like to think they would.
  9. tinkerinWstuff
    The end user is in fact held to the same standard:
    Motorcycles | On-road Vehicles and Engines | US EPA
    http://www.epa.gov/otaq/regs/roadbike/420f03045.pdf
    But seriously - with the exception of the air injection pumps (which do not affect performance) and the cat' converter, the remaining key to lowering harmful emissions is getting every drop of usable energy from the fuel. That means maximizing performance. Keeping the air fuel ratio maintained to an exact level throughout the RPM and load range means best performance, best economy, and best possible emissions.
    Just compare the muscle cars of the late 60's and 70's to their counterpart today. The mileage and HP are more than double while meeting today's emissions standards. Sure, the chassis might weigh half as much in some cases helping the mileage numbers but look at the torque and HP coming out of today's engine technology - all while still meeting these scary emissions regulations.
    From the same PDF linked above:
  10. tinkerinWstuff
    one more thing, just to be clear;
    I'm not saying there isn't a thing out there the end user back yard mechanic cannot do to get more from their bike. I'm only saying that it's going to be more involved than drilling holes in an airbox or similar Red Green duct tape mechanics. You have to apply real engineering and TESTING.
  11. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Tink we are not talking carbed bikes here.
    The Honda engineers plugged up the airbox for noise regulations, plain and simple, that's it.
    They run the smallest hole allowable for the engine to still run relatively efficiently.
    Do I have to find the thread where the guy ran back to back runs with and with out the snorkel and flapper to appease you? It made an average of .5 hp every where , untuned. Not major power, but it did not lose power and proved that the snorkel/flapper were thrown on the box to regulate noise, and nothing else.
  12. tinkerinWstuff
    I just need to see the noise regulation. CFR ???
  13. BereaVFR
    BereaVFR New Member
    Berea, KY
    Thanks for the follow up.
  14. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    What noise regulation do you want me to find? I don't see how that would prove anything. It would just say that the bike needs to be below a certain decibel up to half the rpm of its peak. That's why there is a flapper, to keep the induction noise down to a predetermined level, then at say 5 or 6 thousand rpms, it doesn't matter any more and then they let the engine breathe. That was the whole idea behind vtec, and why the rpm level where peak power is made was lowered on the new cbr1000 and r1 only in the us markets.
  15. tinkerinWstuff
    My engine building sources say that engines with fewer valves have more low end torque while more valves is higher peak HP. That's why there is Vtec and why other bikes like the Shadow ran 3 valves per cylinder. Are you suggesting Vtec was put on the Honda Civic to control intake noise?
    http://www.autozine.org/technical_school/engine/Multivalve.html
    The other link on airboxes also says that they are designed to manage air flow and resonance our sound waves that affect the flow of air into the cylinders. Same reason people had to re-jet carbs when making an airbox change or exhaust modification. There is more science involved here as opposed to the government or mother Honda trying to keep the poor consumer down.
    Resonant Air boxes: Theory and Applications
    I'm just not one for taking internet hear-say as fact. So if you can locate a "regulation" that I can read then I'll be a believer.
  16. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    do we have to do this every winter? as soon as snow hits the ground, when ever anyone touches their bike, you need 4 forms of id and a notary to not think what they're doing to their bike is stupid. lets just agree to disagree.
  17. tinkerinWstuff
    ok. I just hoped to learn something new if you had information to support the claims.
    Making changes to your (anyone's) bike isn't "stupid" as long as the actions support the goal.
    Have a happy and safe New Year!
  18. BereaVFR
    BereaVFR New Member
    Berea, KY
    I have a different perspective on it. I know very little about fuel injection systems and how to increase their performance. This kind of disagreement/discussion gives me a chance to learn new stuff.
  19. 91talon
    91talon New Member
    SW MO
    Just speaking from a primarily automotive background, and messing with imports for the past 15 or so years, MAP equipped vehicles are much more forgiving in regards to intake modifications than MAF equipped cars. That being said, it wouldn't surprise me that because of this, relatively small gains are seen when messing with the airbox, because your pressure isn't really changing, and yes you can actually decrease your pressure sometimes. Short of installing a turbo/supercharger that will increase your air pressure, you're not going to see a whole lot of gains, unless you do some other supporting mods.
  20. 91talon
    91talon New Member
    SW MO
    Also, regarding noise regulations...
    40 CFR 205.152 subpart D, pertains to motorcycles, but that is for noise emissions. Not sure if that snorkle has much, if any, impact on the noise levels of the exhaust, but there are regulations for how loud a bike can be from the factory.
