Speedohealer installation
Discussion in '8th Generation 2014-Present' started by mansonitefirefox, Feb 25, 2016.
  1. mansonitefirefox
    mansonitefirefox New Member
    Simple... Where is the 3 wire speed sensor loom on a 2014+ VFR800 8th Gen.
    Sent from my E6553 using Tapatalk
  2. mansonitefirefox
    Bump. Still trying to find it.
  3. sunofwolf
    sunofwolf New Member
    my speedo healer never left its box, I had it for 1 year
  4. mansonitefirefox
    Meaning you never figured out how to install it???
  5. sunofwolf
    too much work for me, I go back to stock chain too.
  6. mansonitefirefox
    You obviously didn't try very hard.
    For anyone in the future
  7. V4toTour
    V4toTour New Member
    As for the actual sensor itself, I can't speak for the 2014 but it's worth a look. Check the clutch slave cylinder on the left side of the bike. The sensor may live in that assembly plate situated directly over the front sprocket (it does on the fifth gens at least). If there's some wires poking out of that area pretty safe bet that's what that is. There's a plastic socket that drives the sensor, it fits over the bolt holding the front sprocket to the counter shaft.
    I'd thought Honda may have moved to a wheel pickup, but the only thing I can find on the parts fiche for the wheels are the ABS sensor and associated pulse ring.
    Edit: looks like you answered your own question
  8. sunofwolf
    I heal it going back to stock
