speedo issue
Discussion in 'General VFR Discussions' started by volmann, Dec 5, 2015.
  1. volmann
    volmann New Member
    Johnson City TN
    speedo issue UPDAYE
    it works right till about 40 matches GPS...than after that not right
    i can be doing 60 according to GPS and speedo only shows 45 or so
  2. 34468 Randy
    That is really odd. Most time the bikes's speedo reads faster than gps which is the most accurate. You running stock sized tires?
  3. volmann
    volmann New Member
    Johnson City TN
    yes stock
    it works right anything below 40....than it cant keep up
  4. 34468 Randy
    Is it a digital readout or does it have a needle. If it is the needle type, there may be a stepper motor that has pooped out. I don't know how available they are for bikes, but they are readily available for GM trucks, cheap on line ($15.00 for 6) and easy to replace with a little patience and a steady hand.
  5. RVFR
    Wonder if it's the drive thingamajig there behind the counter shaft cover where it isn't able to keep traction.
  6. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    The 3rd gen uses the cable system. If the cable and connectors are good on both ends, then the meter is probably toast.
  7. volmann
    volmann New Member
    Johnson City TN
    Today its worse reading 35 but really doing about 60..it was working right a few days ago
    I want it working right do i have to change the whole cluster...they are about 60 to 80.00 on ebay
  8. V4toTour
    V4toTour New Member
    issues with mechanical speedometers can be sometimes remedied with a shot of wd-40 directly into the housing (worked on an old goldwing I had). Remove the cable drive and gauge, hold the gauge face up (if you hold it face down the cleaner will pool on the gauge face and probably ruin the graphic). Give a quick shot or two into the cable drive opening, let excess cleaner drain out. Put everything back together and go for a ride. I think on Honda clocks of that vintage there's a plastic doohicky where the cable inserts into the gauge, make sure it's not worn. also worn cable ends could be slipping, everything should be square/
    might be worthwhile to spray some "cable life" down through your speedometer cable while you're at it.
  9. NormK
    NormK New Member
    I did the WD 40 trick on an Enfield interceptor a few years ago and I got some on the dial face. Ended up removing the bezel to clean the face, wiped it clean and it restored the faded dial to its original colour. Problem is now the tacho is still the faded colour, so I will have to pull that one apart to clean the face up. Anyway the speedo works fine now after the WD spray
  10. volmann
    volmann New Member
    Johnson City TN
    Fixed it
    the drive at the end of the cable at the clutch pedal ....took it off the little white plastic wheel had come loose.It was not pushed down in the slotted hole good
    i pushed it back in good took bike down road and speedo is correct again
