ride with carbs needing to be synced??
Discussion in 'Mechanics Garage' started by OSA 06, Jul 8, 2011.
  1. OSA 06
    OSA 06 New Member
    Washington, IN
    I just FINALLY, after a lot of work and a ton of money, got my 3rd gen running!! Took it for a short test drive, and the only real issue at the time is the bit of a knock right off of idle from needing to do a carb sync. Does anyone know how long, or if, I can get away with riding the bike like this while i'm waiting to borrow a vacuum gauge set to do the sync?? Thanks in advance. Eric
  2. tinkerinWstuff
    dunno. But bumping the idle up a bit should help if there's just no keeping your ass off it the bike until it's done right.
  3. OSA 06
    OSA 06 New Member
    Washington, IN
    ha..... I'm not gonna lie....I've been itching through the last 4 months of working on this thing to ride it... sitting on it and yelling VROOOOMMM, just doesn't quite cut it... lol
  4. squirrelman
    Ride it until you do the synch. Most synch issues are most evident at and a bit above idle speed and at low throttle openings.
