restoring & adding a modern touch to a 86 vf500
Discussion in '1st & 2nd Generation 1983-1989' started by matt1986vf500f, Jan 14, 2009.
  1. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    yes its a true rear wheel hp very low indeed
  2. invisible cities
    invisible cities New Member
    new york
    Hmm, this is a head scratcher. You are about 20 ponies shy of where a stock '86 should be - at least from what I've read.
  3. tinkerinWstuff
    When he said that, I thought the same thing. Not just 20 ponies but percentage wise, that's like 40% of what it should have had. Probably had a carb issue before he started (i.e. improper jetting etc..)
    Provided it passes a compression test, with those new carbs and the exhaust, it will feel like twice the bike you had before :biggrin:
  4. matt1986vf500f
    never done a compression test to never felt like it was needed i might do one when i pull the motor out of the bike this winter
  5. invisible cities
    new york
    compression test
    Sounds like a good plan :thumbsup:
  6. matt1986vf500f
    got a update for ya'll my revalved forks from jamie came in today and the 85 carbs the forks look awesome jamie you've done a great job if the bike was running i would slap those bad boys on there and take up the mountain!, the forks are no longer damping rods its has 900RR internals with ohlins valves and i forget who makes the springs but they where custom lenght springs! cant wait!!
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    Nice!
    Did you have the Fork Tubes painted before you brought them to Jamie for the rebuild....they look new.
  8. tinkerinWstuff
    them is purdy - no doubt about it.
  9. tinkerinWstuff
    Since you said you aren't using them anyway; maybe I can borrow them and test them out for you this weekend?
    I was hopeing my fork seals would come in today but no call from Honda parts...
    Hopefully tomorrow or I'm S.O.L.
    Planning on going here on Friday, checkout them curves:
    http://www.nps.gov/carto/PDF/COLMmap1.pdf
  10. matt1986vf500f
    while jamie had them he powder coated them for me i picked them up off ebay as a spare set knowning i was going to do a more aggressive fork valving
  11. matt1986vf500f
    nah i've waited a long time for these puppies, that road looks awesome no doubt!
  12. slowbird
    slowbird Member
    Toronto, Ontario.
    I also grabbed a spare set knowing I was going to get some fork work done.
    I've been thinking about sending them to Jamie to get him to work on them (Not as crazy as he did on yours)
    I've been debating whether I should have them painted before or after the work....but powdercoating...that's always good too.
  13. matt1986vf500f
    for me i like powder coating i would do it before the for is done while the fork legs are apart
  14. tinkerinWstuff
    I'm pretty sure you need to do it this way because of the oven bake. Wouldn't the seals be damaged otherwise?
  15. matt1986vf500f
    yes'm that right the seals and dust covers would get cooked
  16. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    The springs were made to my custom specifications by Sonic. Great guys over there. The need for custom springs was one of the hurdles that I wasn't expecting with this project, but in the end it was all worth it!
  17. matt1986vf500f
    i dont know if this right to say but you out did your self on these forks jamie so far i am very impressed!
    another thing i need from you guys is a cbr f2 front wheel (white)
  18. crustyrider
    crustyrider New Member
    North Country, New York
    I was actually just wondering when you were gonna get a white wheel for the front.....
  19. JamieDaugherty
    Fort Wayne, IN
    Thanks man!
    Just make sure this one doesn't get lost in the mail this time.
  20. slowbird
    slowbird Member
    Toronto, Ontario.
    I was looking for an F2 Front for my bike but everyone around here wants around $200 for them. :frown:
    What's the other wheel option for front wheel conversion?
