Rear light connectors
Discussion in 'General VFR Discussions' started by Braaahhnz, Dec 8, 2015.
  1. Braaahhnz
    Braaahhnz New Member
    Staffordshire, UK
    Hi, hoping for some help please. I'm trying to find out the part number, manufacturer or where I can buy boy the male and female and associated terminals for the rear light cluster on the gen 6.
    [​IMG][​IMG][​IMG][​IMG]
    Help will be very much appreciated.
  2. GigemVFR
    GigemVFR New Member
    TEXAS
  3. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Why does it have to be that connector? Just replace it with quality 2mm or 3mm bullet connectors. :)
    They will protect the connection far better (less likely to oxidize as they can hold di-electric grease and have more contact surface) and they will function better as well.
  4. SlideRule
    SlideRule New Member
    Temecula, CA
    Jim from Eastern Beaver has them:
    Link: Honda Brake/Tail/Signal Connectors
    Unfortunately he has a $20 minimum order, so I usually stock up on additional connectors & terminals whenever I order from him.
    He has access to many of the connectors used on our bikes, including R/R & weatherproof connectors.
    No affiliation, just a happy customer.
  5. Braaahhnz
    Staffordshire, UK
    Thanks guys but I'm really after the female side of the connector.
    I want to break into the circuit without hacking the Harness which will allow me to return to oe if/when I decide to sell the old girl (not the wife but a more likely situation) ;)
    Sent from my SM-G900F using Tapatalk
  6. Dead Eye Dick AKA Carpy
    Dead Eye Dick AKA Carpy New Member
    Chill Out City
    Hey fella
    Why don't you make up 3 "Flying Leads" to go between the Female and male plugs, i.e. 3 wires with a micro spade male on one end and a female on the other end so you can scotchlock into those instead of the harness. When you want to revert to standard, just remove the leads and plug the harness back together as normal.
    Good Luck
    Carpy
  7. Braaahhnz
    Staffordshire, UK
    That's a decent idea. If I still can't find the female connector after tonight then that is a good way to go.
    Thank you
  8. Knight
    Knight New Member
    USA
    The Honda Common Service manual calls the connectors by letter, and I think they are calling this one "type B". (The diagram is not quite clear.) Outside of Honda references I found similar connectors designated for "motorcycles" designated such:
    3-position 110 connector
    type B 110 connector
    Sumitomo MTW series 110(2.8mm)
    Here are some online suppliers:
    http://www.cycleterminal.com/110-connectors.html
    http://www.corsa-technic.com/category.php?category_id=53
    I see the Honda female end looks a little different from these. Unclear if you would have to replace both or if the generic one would connect right up.
    I think these connectors are designated opposite of what you said, male/female, based on the pin male/female configuration, not on the nylon housing male/female configuration.
  9. Braaahhnz
    Staffordshire, UK
    Ordered from cycle terminal. Hopefully they'll fit.
  10. Braaahhnz
    Staffordshire, UK
    And drum role please ............ "BOLLOCKS!" They didn't fit.
    The terminals on the bike are 6mm pitch (measured after I tried to fit the ones I bought). Lesson from this .... measure the f#$king pitch of the terminals before ordering!
  11. Braaahhnz
    Staffordshire, UK
    SlideRule has put up a picture of what I'm looking for but I need the mating side too. Does anyone have any suggestions other than just connecting the terminals and filling the connector?
  12. Knight
    Knight New Member
    USA
    Wow. Thanks for being a guinea pig. How utterly ridiculous as well as disappointing.
  13. Scubalong
