Problem with my 99
Discussion in 'Mechanics Garage' started by 79cbxr, Jul 13, 2014.
  1. kennybobby
    kennybobby New Member
    Who knows what goes on inside the mind of a power commander--how does it fake out the ECU, what does it do with sensor inputs, does it inhibit FI codes, etc? It seems that the best you can do is verify all the OEM stuff until you find the culprit or rule everything out until it points to the PC.
  2. 79cbxr
    79cbxr New Member
    Mason, Ohio
    Not sure what goes on in the Power Commander either... I do know it makes no difference whether it is connected or not. I've tried disconneting it/ reconnecting it twice. No difference.. If anything, it's better with the PC connected.
  3. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    $30 shipped, PM me if you want. But, if the ECU is the problem and you don't have a CA spec bike it's not going to run too well. It should run but power is going to be off. I bought my 49 state ECU for $100 on eBay.
  4. 79cbxr
    79cbxr New Member
    Mason, Ohio
    Well, I tried VFRCapn's CA spec ECU to no avail. (Thanks, Mike) Everything is the same. It will start immediately if you spray fuel or starting fluid in the airbox. The next thing I am checking is for voltage pulse at the injectors. I know I have fuel pressure and spark. I'm thinking the fuel injectors aren't getting the proper signal to open at startup ( and all the time, for that matter).
  5. tinkerinWstuff
    This has drug on a long time, I don't recall the details; but have you checked the orange ground buss connection?
  6. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I have not checked the orange ground buss connection. Where would I find it? And you're so right, It has drug on all summer. Killing me. Thanks for hanging in there with this.
  7. tinkerinWstuff
    Known failure point on 5th gen VFR. Poor connections start to burn and char causing bike to quit running.
    Gotta be worth a look.
  8. 79cbxr
    79cbxr New Member
    Mason, Ohio
    Wow. I do know my bike has the upgraded R&R with heavy duty wiring harness.. but.... Maybe there was some damage done before it was replaced. Last night I got intense with the Honda shop manual & meter and I may have tracked the problem down to a bad wire from ECU to TPS. Maybe that wire is damaged at the buss? As soon as I get home from work today I will find out if that's the problem. I cant' tell you guys how much I appreciate all the input.
  9. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I give up. All three wires from the ECU have continuity from the connector side of ecu and TPS. Anyone wanna buy a used, F'd up VFR?
  10. kennybobby
    what about the TPOS sensor it's self--i've had lots of trouble tracking down issues with tps because it can be intermittent, working at times and flaky at others, never failing completely. Is anyone around with a known-to-be-good sensor that he can use to troubleshoot this thang?
  11. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I have swapped out the TPS with one that came on a throttle body setup I got off of eBay. Before installing it, I tested them on the bench. They tested exactly the same and seem to be just fine. I have tried everything I know and all of the stuff recomended here. Including different TPS, MAP sensor, Fuel pressure regulator, a different ECU. I am getting 8 flashes from the FI light ( which the Honda manual diagnoses as TPS. ) One wire is getting the correct voltage one is getting less than spec. but the wires are checking good continuity all the way through the harness... so......?
  12. tinkerinWstuff
    Did I miss where you checked the orange ground buss?
  13. John451
    John451 Member
    Not sure is the same fault but a few years back mine lost fuel economy mid range and high end power, mine was caused by a front bank pair valve stuck open, ( mine was also backfiring intermittently ) I first fixed it following below Link finding one Pair valve was visibly stuck open then later blocked them all for good.
    See below Link to UK VFR site explaining symptoms and fix:
    http://www.bikersoracle.com/vfr/forum/showthread.php?t=76563
  14. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I did check the orange ground buss yesterday. Just didn't mention it.
  15. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I did try another TPS from a throttle body setup I got off of ebay. I checked the one from my bike and the "new" one on the bench before installation. they checked exactly the same from idle position to wide open throttle. The "new one" did not change anything. Newest development.... I have FI fault light. 8 blinks. TPS fault according to Honda Shop manual. Wires from TPS check good. I get 0.1 volt on the Green wire with orange stripe ( should be 5 volts). This tells me that the ECU isn't sending 5 volts to the TPS on that wire.
  16. 79cbxr
    79cbxr New Member
    Mason, Ohio
    And... I did check out the orange ground buss and it looks fine.. no scorching or hot spots.
  17. rjgti
    rjgti New Member
    regina sk
    there should be an adj to set it up at key on/engine off voltage
  18. 79cbxr
    79cbxr New Member
    Mason, Ohio
    I'm not sure where an adjustment could be made?
  19. rjgti
    rjgti New Member
    regina sk
    are mounting holes not slotted?
  20. 79cbxr
    79cbxr New Member
    Mason, Ohio
    Mounting holes on tps are slotted. I don't believe tps is the problem.
