Plastic fairing fasteners
Discussion in 'Mechanics Garage' started by tyarosevich, Jul 30, 2012.
  1. tyarosevich
    tyarosevich New Member
    Seattle, WA
    I'm posting this video for posterity as I couldn't find any similar ones with a quick search. This is my ghetto method for popping the fairing fastener's on my 2009 VFR800. I assume other Honda fairing fasteners from this era are identical and/or similar, and my hope is that this might help someone out there avoid breaking a few as I did. I'm demonstrating with a fastener in my hand, and furthermore with one that is already broken. As you can see, the two little flaps that lift up have been broken off leaving the center plastic part with a round head. It should have two little tabs that you can wiggle a flathead under in the same way. Others have posted that they're easy to understand if you try, and while this is true, I'm sure there are other impatient knuckleheads out there like me. Hopefully this will be of use to them!
    I must throw in the caveat that I know my nails look disgusting, but I play classical guitar and therefore must maintain slightly long nails on my right hand...it sucks for working on bikes, and I know it looks gross :tongue:
    [video=youtube;-b9KR1vYWlk]http://www.youtube.com/watch?v=-b9KR1vYWlk&feature=youtu.be[/video]
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The '09 fasteners must be different from the '99. I've bought a couple in the last 12 years to replace a couple broken ones, but they rarely break. But I push in the center, not pry out with a screwdriver. Removal is rarely an issue, but the ones on the bottom of the fairing are the most likely to break due to road goop.
    Okay, I didn't listen to the video clip so maybe I missed something, watched but didn't listen.
  3. stoshmonster
    stoshmonster New Member
  4. tyarosevich
    Seattle, WA
    There's no audio. Evidently pushing the center doo-dad in is the correct way of removing them, but personally I had trouble getting it to work on flexible fairing pieces, hence the broken ones. That being said, stoshmonster is probably the one you should listen to since I am :crazy:
  5. stoshmonster
    Don't feel too bad my friend. I'm not ashamed to admit that I broke a coupla three four of those *%#$@* goofy plastic panel fasteners myself before I figured out the correct way to remove/install them.
    To be honest,even though I know the secret now I still somehow manage to break one of them every now and then. :redface:
  6. tyarosevich
    Seattle, WA
    I'm tellin' ya', the flathead method!! :chaingun:
  7. 34468 Randy
    Yeppers. Broke a few of those myself. And the stealership charges about $5.00 each for those little fuggers.
    But alas: --BOLT Motorcycle Hardware--
    The M6 are the ones that I use now. Better than OEM. Those two on the bottom of the faring are particularily bad seems. The M7 Pry clip might be the answwer there. They are new.
  8. CAL2003
    CAL2003 New Member
    Austin, TX
    Thanks to tyarosevich for posting the video. Wish I had watched it before trashing mine. At least I know for next time. And thanks to 34468 Randy for posting the type/size of rivet.
  9. tyarosevich
    Seattle, WA
    It's worth noting that this isn't the right way of removing these fasteners, and is useful with broken ones. The proper way is to push firmly in the middle...
  10. Badbilly
    Google (or BING man, man!) "push rivets".
    The uber cool dudes use Dzus fasteners.
  11. SinNH
    SinNH New Member
    Got my M6 and M8 through FleBay from Bosspowersports outlet, five bucks for a bag of 15, free shipping
  12. CAL2003
    CAL2003 New Member
    Austin, TX
    I found a similar deal on Amazon. Thanks again for all the help team.
  13. actungbaby
    actungbaby New Member
    On side tangent i know but my front faring smashed up but i brought the little fairing blade that goes between front headlight (rc 36) but the brass insert missing from left side middle fairing or top i forget, but can you buy these
    They seem to be press fit at the factory unless you chould glue them in place ?
  14. 34468 Randy
    I can't quite place what you are referring to here. Could they be the well nuts? If so, they are readily available at the shop, maybe elsewhere too but I don't know. Photographs would help. Any part on your bike should be available as OEM from the shop. But as we all know, OEM are reduculously expensive.
  15. Saracen
    Saracen New Member
    Leesburg, VA
  16. actungbaby
    I get a picture up tommrow no the 92 fairings arent availible anymore
  17. junkins45
    junkins45 New Member
    Keyser, WV
  18. Badbilly
    The critters are called "push rivets" . Google provides.. Honda calls them by different name translated from Japanese meaning, "bend over sucker."
