Pipercross air filter dull stuff
Discussion in 'Gear & Accessories' started by Tony Whitwham, Jan 19, 2019.
  1. Tony Whitwham
    Tony Whitwham New Member
    Southampton
    January boredom got the better of me and I measured and calculated the areas....dull I know VFR Air filters.jpg
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    The amount of filter doesn't really matter once you get past enough area so there's no restriction. If the Honda
    OEM filter works with no restrictions, then the Pipercross just looks cool. Bigger isn't necessarily better, sometimes
    it's just bigger.
    OTOH if you can post the flow chart for the VFR at full throttle, and compare that to what these filters will flow, then
    you might be on to something. But if you had access to a full throttle flow chart, you'd probably see that the OEM
    filter is more than sufficient. But JMO of course.
  3. fink
    fink Member
    Sounds a nicer
