PCV or Two Brothers Juice Box Pro or 2010 VFR 1200?
Discussion in '7th Generation 2010-Present' started by 88SILVERGT, Dec 31, 2011.
  1. dynajohn
    dynajohn New Member
    KY
    The cheap answer for the 1st & 2nd gear power restriction is a Bazzaz Zbomb which costs around $65. It plugs into the wiring harness and fools the ECU into thinking the bike is in 3rd gear when it is 1st or 2nd gear. Only downside is the gear indicator indicates 3rd gear when you are in 1st or 2nd gear. The better answer is to contact Don Guhl at Guhl Motors and arrange to have the ECU re-flashed. This costs $350 and you get rid of the 1st & 2nd gear restrictions at the source. In addition you get a re-flashed fuel map which eliminates the need for a fuel controller like the PC5 or Bazzaz product and some other features if you want them. The $350 is way less than either a PC 5 or a Bazzaz with the autotune feature not counting having it installed if you can't do it yourself.
    #41
  2. ricknpb
    ricknpb New Member
    Thank you, Dynajohn. Appreciate your reply.
    #42
