Not a Teaser! 1983 VF750F resto project
Discussion in '1st & 2nd Generation 1983-1989' started by Sebspeed, Feb 7, 2008.
  1. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Awesome...just awesome.
    Wish there where more people like you and Jamie D!
    BZ
    #61
  2. MrJoelieC
    MrJoelieC New Member
    Milford NH
    :jaw: Please hold while I mop up the drool from the PC'ed frame....
    #62
  3. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Seems like we're in dire need of an update here!:rolleyes:
    So, I finally got a little more done on the bike! I assembled the second fork and it went together well, and it works a lot better than it did before... the only thing I did differently during assembly was to hold the fork upright when I tightened the bottom bolt with my impact gun, where last time I held it horizontally. Huh. Any way, it works now, so... on the bike it goes!
    Used the old steering bearing races to tap in the new ones, I had planned to borrow the special tool from the local Honda dealer, but they didn't have the one I needed.
    Got the lower triple in:
    Checked my clearances to the frame on either side; the triple was hitting the frame before I modified the stop with a pair of screws, looks like they worked out pretty well! I retained a lot of the steering travel, and the triple doesn't hit the frame.
    Right side:
    Left side:
    Upper triple is in, with the right leg:
    Used a VTEC top bridge nut & steering plug, and you can see the Yoshimura F3 billet clip on there:
    My son helped me tap out the holes for the rotor bolts(dirty in the first place, plus glass bead leftovers):
    Then I bolted the rotors on that I painted a while back, and threw the wheel up on the lift as well as installed the other fork leg:
    I'm digging the black on white! :thumbsup:
    If you didn't notice in those pics, there is a custom fork brace in there that Jamie Daugherty designed and had another guy machine for me, it's made to bolt on the 1000R forks and hold a 750F fender! Yay!! I'm not liking the rough machine finish, so I will be sanding and polishing that piece at some point, it's too nice to paint black, but looks rough as-is.
    I spent an evening with my regulator-rectifier/fuel pump bracket, and this turned out real nice. I am going to try out the gravity feed fuel setup, so I got rid of the pump for now, removed the R/R, and degreased the whole plastic bracket. It cleaned up really well, and looks like new now! Here it is with the R/R back on(the bolts were wire wheeled before reassembly):
    Another little success story here is the shock linkage. Man, was that thing dirty! It had a layer of grime like you wouldn't believe... and the linkage arms(I like to call them drumsticks) were pretty rusty. Another can of degreaser, a little glass bead blasting, and a spritz of paint later - much better!
    Installed:
    Other side:
    In that pic you can see the foam I filled the swingarm with, it's just the stuff that comes in the can "Great Stuff" it's called.
    I put the cush rubbers back in the F2 wheel, slipped on the specially machined hub, and then, finally, after much ado, I have a rolling chassis!!
    Seeing that got me motivated to install the brand new upper fairing stay that I bought 2 years ago, it was damaged during shipping & so I had to spend about 45 minutes with various tools to get it just right again, but it's about perfect now.
    Then I just had to throw the new headlight in to see how it would look, I think it's going to be pretty badass!! :strong:
    Any thoughts, opinions, comments/questions/concerns are welcome!
    #63
  4. ottrod
    ottrod New Member
    Wichita, KS
    ...just found this thread - AMAZING job you are doing! I love really detailed build threads with quality pictures and documentation - Keep it coming!!!!
    Kinda like the resto - mods in the muscle car world!
    Keith
    #64
  5. drewl
    drewl Insider
    Virginia Beach, Va
    DANG, Seb. That thing looks super-dee-duper. Can't wait to see it on the road. Thanks for sharing with us over here, too.
    #65
  6. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    Thanks for the comments guys, appreciate it!
    #66
  7. VFR-Guy2000
    VFR-Guy2000 New Member
    Holladay, Utah
    That thing is starting to look soo sweet! I can't wait to see the finished outcome. that pic of the rolling chassis just looks so awesome especially with those rims & tires.
    #67
  8. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    I'm not too happy with the looks of the large-sidewall rear tire. Would like to go to something smaller in the future, but that means adding ride height and changing gearing to make up for the (overall height) smaller rear tire...
    I also just won a 900RR 5.5" rear wheel, so I might try to jam a 180 in there!
    #68
  9. Bernieswanson
    Bernieswanson New Member
    Bellevue, WA
    Not like your daddys Interceptor
    That's what I'd tell my son. My first brand new motorcycle was one of these in 1983. It was my 3rd or 4th bike. I loved it till gen two came along and bought a new 1986 VFR750F.
    Keep up the work and postings as we watch her incubate in your shop. I'll raise a wee bit of my finest single malt to you on her (re)maiden ride.
    Cheers
    #69
  10. masonv45
    masonv45 New Member
    The PO mounted a 160/60 Avon Azaro on the rear of my bike and so far, no problems...
    #70
  11. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    What size is your rear wheel?
    #71
  12. masonv45
    masonv45 New Member
    #72
  13. slowbird
    slowbird Member
    Toronto, Ontario.
    Bike looks great.
    Love the Stain Black on white.
    #73
  14. Outlawz24
    Outlawz24 New Member
    Lloydminster Sask
    Bike is looking great man! Hopefully soon i will have a project thread of my own again once i start working on my VF..Already removed the decals off of it in preperation of an upcoming rattle can paint job for now...
    #74
  15. Richard Thompson
    Richard Thompson New Member
    Auckland, New Zealand, New Zealand
    im subscribing to this thread so i can follow the progress.
    geat work! i love to see these older bikes come back to life.
    #75
  16. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    Great looking project Seb.
    You are gonna hate yourself for using white rims.
    they are next to impossible to keep clean. voice of experience
    owned a 1986 vfr700f2 in pearl white with white rims
    white rims were payback for hiroshima
    Beautiful work. keep it up.
    #76
  17. VsVFR
    VsVFR New Member
    Western KY
    That is too funny!!!!
    And awesome job on the project Seb!! Thanks! Keeps making me long for a project. Maybe I can run across something in the next couple of months just in time for winter.
    Great job!!
    #77
  18. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    I will hopefully have an update on this soon, got a few more little things accomplished, and I just realized I haven't posted any pics of the exhaust yet...
    #78
  19. Outlawz24
    Lloydminster Sask
    #79
  20. benjammer
    benjammer New Member
    Bentonville, AR
    Great Work/Documentation. Man I wish I had your skill and patience. I'm subscribing to the thread to follow your progress. Can't wait to see the finished product.
    #80
