Newbie...Midlife crisis...found 1986 VF500F! Need help.
Discussion in 'Introductions' started by finemedic, Feb 26, 2011.
  1. finemedic
    finemedic New Member
    Cincinnati, Ohio
    No I have not taken the valve covers off yet. I am gonna pull carbs again today clean the enrichment tubes. Pull the valve covers and adjust the valves. I am calling the Honda dealer today to see if they have gaskets. Only thing I can figure is that the cylinder heated up for the first time in years and the gasket went bad. All the help has been great. Back the the barn for some more wrenching today!
  2. invisible cities
    invisible cities New Member
    new york
    When ordering the new gaskets for the cam covers you may want to also order a set of new 'boots' for the carbs. This will make the carb install much easier.
  3. finemedic
    Cincinnati, Ohio
    I about had a stroke when I called for prices on the carb floats! $48 a piece! The bowl gaskets $46...The floats are a little chewed up and I thought I might as well replace them when I have the carbs apart...They work its going back together...
    Can anyone send me a link to the least expensive HONDA OEM part supplier?
  4. invisible cities
    new york
  5. finemedic
    Cincinnati, Ohio
    I only seem to get about the wire about 1/2 down into the enricher tube???
  6. finemedic
    Cincinnati, Ohio
    I mean about 1/2" down into the tube....
  7. superhawk73
    superhawk73 New Member
    I know this be an old thread but I had that blown valve cover gasket a couple of decades ago. Ended up the I put the hose to recirculate the blowby gases from the crank to a the wrong spigot on the plenum. I put it on one that was blocked off vice one that put the gases back into the intake to keep emissions down. The pressure build-up blew the seal with the least tolerance for pressure - the valve cover gasket. It is only designed to keep spray oil in, not hold in pressure (which can be up to around min 160 psi, much greater on the combustion stroke. Just ensure that second hose that goes to the plenum goes to a spigot with a clear hole in it.
  8. volks6000
    volks6000 New Member
    Jacksonville , Florida
    you also might want to check with bikebandit.com
