New Bike, New problems!
Discussion in '3rd & 4th Generation 1990-1997' started by Boostedpower, Apr 4, 2010.
  1. tinkerinWstuff
  2. afpierce489
    afpierce489 New Member
    Cape Cod, MA
    I don't know what else I can do but to spoon feed you the info. I gave you the link to the PDF manual. The test is on page 15-6. However here goes the procedure straight from Haynes:
    1. To reach the R/R unit, remove the seat and either the left side cover or the rear fairing, according to model.
    2. Connect the (-) negative probe of a mulit-meter to a suitable ground (earth) point then switch the ignition switch ON and carry out the following checks:
    3. Set the mulitmeter to the 0-20vdc setting then connect the meter positive (+) probe to the red/white terminal of the wiring connector and check for voltage. Full battery voltage should be present. Switch the ignition OFF.
    4. Switch the mulitmeter to the resistance (ohms) scale. Disconnect the wire connector from the r/r unit and make the following test on the wire harness side of the connector. Check for continuity between the green terminal of the wiring connector and ground (earth) then check the resistance between the yellow terminals of the wiring connector. There should be continuity between the green terminal and ground (earth) and a resistance reading of 0.1 to 2.0 ohms should be obtained between each pair of the yellow terminals of the wiring connector.
    5. If the above checks do not provide the expected results check the wiring between the battery, r/r and alternator.
    6. If the wiring checks out, the r/r unit is probably faulty. To check the unit, unplug its wire connector and remove it from the machine. Using a mulitmeter set to the appropriate resistance scale, check the resistance between the various terminals of the r/r. If the reading do not compare with those shown in the table, the r/r unit can be considered faulty.
    NOTE: The use of certain multimeters could lead to false readings being obtained. Therefore, if the above check shows the r/r unit to be faulty, take the unit to a Honda dealer for confirmation of it's condition before replacing it.
    Try this out. Let me know if you need something else.
  3. tinkerinWstuff
    Can I get it in braille? I would like to keep it on file for when this happens to mine. As soon as I get that dam rod bearing fixed :pout:
    Sorry, kinda mean, couldn't help it.
    Good luck with your bike man!
  4. afpierce489
    Cape Cod, MA
    Sorry, didn't mean to come off as being mean.
  5. Boostedpower
    Boostedpower New Member
    while on battery read 11.74v at the battery, while ignition on and tested the red wire on the rectifier it read 10.89
  6. Boostedpower
    between the ground and green 0.9-1.4
    yellow reads OL when touched to ground on ohms
  7. Boostedpower
    should I start the bike?
  8. derstuka
    San Diego, CA
    Guys, I would give up. This guy is ignoring you all when you are trying to be helpful. He has all of the info that he needs. He only needs to pay attention, read and search. Only thing you didn't do is drive to his house and do it for him. You better get that spoon ready.
    Then again, if you have nothing better to do than waste time repeating yourself over and over, knock ya self out.
    :faint:
  9. Boostedpower
    Look electrical is not my thing, and I don't have the money to take it anywhere I am doing this step by step and giving you guys the readings so I can figure out if its my rectifier or stator, and personally your a d*ck dude, all I did was ask for a little help and I am giving you the readings, all I asked was should the bike be running or just in the on position...
  10. betarace
    betarace New Member
    Middleburg, VA
    I would disagree, we have all tried to be helpful in your many posts, and in chat. If you dont follow the directions, we cant help. To simplify your life (and ours), replace the rectifier and stator and move on. They are $115 each at wiremybike.com best of luck
  11. 2wheel`tone
    2wheel`tone New Member
    Richmond, VA
    Then I lol'd
    Lol'd again
    Really LOL'D
    Helpful Post #1
    Helpful Post #2
    Helpful Post #3
    Helpful post #4
    Helpful Post #5
    Whats this? Another one?
    Damn, another helpful post?
    This guy doesnt offer much advice, so his posts really dont count.
    MORE HELP ? See the pattern that is starting here?
    ..............................wow.................just...............wow
    Here comes the choo choo, chuga luga chuga luga, chooo chooo. Open wide little Johnny.
    O'rly
  12. tinkerinWstuff
    Good one 2'wheel. I was crying reading that. :pound:
    What's worse; someone over at VFRD is probably pissing themselves, or go4, the famous birdseed, deepdish?
    This thread might need to be a sticky we can refer all newcomers with RR issues to.
  13. Rchecks
    Rchecks New Member
    Summerville, SC
    Since you are "mechanic" do you test a car altenator with the car running or just in the on position?
    All these posts have told you how to do it. some tests are with it running some with it just set to on, some are with it completely taken off the bike.
  14. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Did VFRD send a troll over here or what?
    BZ
  15. betarace
    betarace New Member
    Middleburg, VA
    I think boostedpower and vfr93 are the same person. Posts are identical and the signup dates are very similar
  16. x-KAZ-x
    x-KAZ-x New Member
    South Africa GP
    WOW............
    Guy seriously most mechanics are NOT dragons, go in to a local one >I'd suggest you trailer the bike in< show them what the problem is and ask for advice.... Usually if you are nice enough about how you ask for help they dispense their advice for free.
    Hell you may just be lucky enough for someone to say they would help you after hours for free.
  17. tinkerinWstuff
    The VFRW Princess has spoken...
    This is case in point of why people should consider supporting their local bike shop instead of trying to save $2.00 by placing your parts orders with some guy in his boxers 8 states away. My local shop has done me right and cut me a freebe on 2 minute assistance jobs after I spent my money with them. They know I shop internet prices before coming in and they are usually $5-$10 more expensive. Normally what I'd pay in shipping. I support the local guy and then they support me when I need it.
  18. betarace
    betarace New Member
    Middleburg, VA
    more good advice that probably will be ignored
  19. x-KAZ-x
    x-KAZ-x New Member
    South Africa GP
    Yea probably, but i feel better for saying it.... And knowing I'l keep getting the free services i get coz I'm not an arse...
  20. vfourbear
    vfourbear New Member
    Cincinnati
    epic............
