Need help! Important front wheel bearing question.
Discussion in 'Mechanics Garage' started by cbrf293g, Apr 14, 2011.
  1. cbrf293g
    cbrf293g New Member
    Camo, no, not even one you can feel, the dark marks on the bottom outer race are just that, from when I used the harbor freight ball bearing driver set to drive the race in.
  2. donald branscom
    donald branscom New Member
    Guerneville CA
    Did you rent that DVD "U TURN " yet????
    You can watch that while you are waiting to get your new front wheel,or used front ebay wheel.
  3. cbrf293g
    cbrf293g New Member
    No not yet, DVD player is on the fritz. Ill see if netflix has it and join back. Also want to see the postman? some guy at work says its good.
    Sooo.... the front wheel is bad enough that it needs replaced? And the back is ok?
