My invention : Home-made mirror extenders...
Discussion in 'Mechanics Garage' started by overrider, Oct 26, 2008.
  1. Spike
    Spike New Member
    I didn't see anywhere where it said prototype. It actually sounded like this was the final version, at least for now.
    Even with the shrink tubing, and I am sure there will be big enough out there, it won't look good; better yes, but not good. It will still look out of place. Having two "arms" go out to the mirror mount, which is a flat oval shape, then to one arm to the mirror. This doesn't really make sense when there are several products already out there designed for just this purpose. Why not use one of them? Unless one comes up with something that looks better or works better, or is easier, it just doesn't make sense. The solid block ones availible aren't expensive and you can get them in aluminum or Delrin, and when installed, they look nearly stock, and are sure to be more stable since it is a flat mounting surface and the screw holes aren't going to be too big.
  2. GoForARide
    GoForARide Banned
    I agree.
    tho thild be pretty easy to have manufactured.
    all it is is a rectangular piece with rounded corners and 2 holes.
    ill be doing this to my new bike.
    may buy one. depends on the price.
  3. deepdish
    deepdish Banned
    i think i'll use some 40oz bottle tops yeah........keep it realllllllllllllllllllllllllllll:reg:
  4. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    To the OP - what happened to your windscreen? It looks like you ran over a deer (or whatever the prevailing species is in Istanbul).
  5. 02 VFR Rider
    02 VFR Rider New Member
    I have made some out of bar stock aluminum 3/8" - 1/2" if there is any interest in this let me know, I can make some more.
    lexan is also availible.
  6. BWeiss
    BWeiss Johnny Partseed
    Rancho Cordova, Ca
    Hey...home made solutions can be a great thing for certain problems...my lisence plate/luggage rack is a perfect example!!
  7. Spike
    Spike New Member
    no idea about your particular project, but I don't think anyone here is against homemade solutions per se, I certainly am not. But sometimes they just don't work out as well as we had hoped. And it doesn't make sense to do this if there are other better solutions out there already. If no one else had addressed this previously, then OK. Or if he said, "I didn't like the other ones out there because XYZ, so I came up wtih this..." that would be one thing.
  8. BWeiss
    Rancho Cordova, Ca
    Exactly...i should have added some context to my post. For SLO III i made some custom luggage brackets to carry some bimmer bags that i have. on the way down, at 90 mph, they experienced an epic fail (twice!!!), and I wound up with a custom license plate.
    before heading out
    after the first fail
    the second fail
  9. TheSkeeter
    TheSkeeter New Member
    Frisco, TX 75034
    Umm, why??
  10. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Are you plan on towing a trailer for those extensions?
  11. Spike
    Spike New Member
    home made solution (in this case) = twice "epic" fail
    that says a lot...
    and those aren't exactly beautiful...
  12. Spike
    Spike New Member
    I thought that was where the Cirque du' Soleil performers hung on for their BIG entrance!:thumbsup:
