My 4th gen story (so far)
Discussion in '3rd & 4th Generation 1990-1997' started by slowbird, Nov 27, 2011.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    I figured since I posted so much in regards to my problematic 1st and 2nd gen bikes....I should make a thread about my 4th gen. About what I've done, what I plan on doing, and how much I love it. (which is a lot) :hump:
    So I purchased it from the original owner sometime in May this year. Had aprox 25,000kms (16,000miles) on it. Looked like this:
    The owner had a 180 tire on the back. Both tires were a few years old and the tread was looking a bit low. I installed a pair of BT-023's and put a 170 stock size on the rear.
    After a few hundred kms I noticed the bike was sputtering or missing above 6,000rpm. The owner claimed he did nothing to the bike except Oil, gas and tires so I decided to take her apart.
    (You can see the OE R/R in one of those pics. I ordered a new one from wiremybike.com and installed it at this time.)
    Anyways, to fix the sputtering/misfire I replaced all 4 spark plugs with factory ones, replaced the dirty OE filter with another factory one. New fuel filter, and even a new sponge/air filter for the PAIR system. Changed the oil with Mobil1 MX4T and the bike felt much better. MPG improved too.
    With the bike running great I moved to the aesthetics.
    Added red (reflective) wheel strips:
    I also added a Dark tint Touring Screen, Clear front signals from "Thurn", and some "V4 gear Driven Cams" decals:
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    Due to the frequent electrical issues of the VFR's I also installed one of these:
    Signal Dynamics | Signal Dynamics Corporation 1-800-785-1814 | Motorcycle Safety Lights | Break Light Signal Module | Motorcycle LED Lighting | Signal Dynamics - Creator of BackOFF
    It works pretty good. It's pretty simple and I installed it in the little rubber peice on the upper portion of the dash under the windscreen. You can see it in this vid:
    Elephant Lake on a VFR - YouTube
    (little green light reflecting on the windscreen above the clock)
    So besides the other mods I mentioned, I also replaced the signal and brake bulbs with LED's, and I installed some black wheel lugs to replace the stock silver ones.
    Here it currently sits in a storage place for the winter:
    I don't have a garage so I had to rent out this 10x10 storage unit so I can comfortable work on the bike over the winter. I have quite a few things planned and I wanted to do it in comfort and in a nice heated place.
    Here is what I have planned over the winter:
    -VFRNess install
    -Check all wiring (re-do splicing of LED load resistors and LED Heads up unit)
    -PAIR removal (I purchased a kit off ebay with block off plates and caps)
    -Replace the OE pads with EBC HH
    -Install HEL Steel brake lines & speed bleeders
    -Replace front and rear sprockets + chain
    -Install Givi rack for Top case
    -Splice in brake light modulator
    -Replace all dash lights with LED's
    I also have some repairs to do as I had a mishap in the driveway involving a heavy bike lying on it's right side and a tiny 140lbs numpty unable to pick it up.
    Gotta replace the rear brake lever and find out why it doesn't activate the brake light unless fully pressed.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    Neat video through a tunnel:[video=youtube;ax-9jqDXW7k]http://www.youtube.com/watch?v=ax-9jqDXW7k[/video]
