Greetings. I am considering lower my 1996 Honda VFR 750 due to my 29-inch inseam leg length. Other than toying with the seat there seems to be 2 options. The dog bone type. Has anyone used the Ebay sold Pro-tek Honda Interceptor 750 Lowering Link Kit? It only has 1 adjustable dog bone (I asked the seller to comfirme) piece instead of 2 like other lowering bones I have seen for other bikes making me question its strength. There does not seem to be much information on a Pro-tek brand but the name is similar to Pro-Tec which is a well established motorcycle aftermarket parts seller with a US address and phone # to call for info. These are affordable but that may be for a reason that I DO NOT WANT TO FIGURE OUT THE HARD WAY. Option #2 are the triangle rear shock link plates type with boltholes closer together. The only 1 I can find for 4th gen Honda is Lust Racing. They are a bit more than I want to spend for a experiment that may not work out. Are there pros and cons for either type of lowering kit? Any help from someone that has done this mod would be much appreciated.
There is only a single dogbone on the VFR linkage, along with the two triangular side plates. I know that on the 800, you can reposition the side plates (rotate them) and lower the bike quite a bit as my own bike had been lowered before I bought it. There's a bit of mucking around but you could check that out before committing to the links. You can also lower the front simply by slipping the fork tubes up through the triple clamps but don't go too far or you could smack the mudguard when the forks are compressed fully.
