It just died!!! Now it won't start. What tha hell goin on.
Discussion in 'Mechanics Garage' started by ToyWG, Jul 4, 2011.
  1. Rangerscott
    Rangerscott New Member
    Texas
    5th gen injector harnesses connect on the left side of the frame. Take the left side fairing off and disconnect the PC from the harness and connect the stock harness back. See what the bike does then. You can also try re-uploading the map to your PC. I've heard of people's PC "forgetting" its map from say a power outage or electrical surge. Once they re-uploaded the map, all was fine.
    Also try wiggling the side stand switch. There's been cases where the wires are making bad connections and the bumping around the road causes the bike to die because the system thinks the stand is down.
  2. ToyWG
    ToyWG New Member
    20 min south of the N.C MTNs
    Wow... Thanks to all for the info and advice. I will check all of them one by one. I will keep you posted on my progress. Wish me luck...
  3. ToyWG
    ToyWG New Member
    Wow...ok, I just bypassed the PC... Turned her over a few times and nothing yet. Now the batt is getting weak so I must stop and charge a while. The wire on the fuel pump looks good but I need to check closer, after the charge. Im gonna change the fuel and go over the wiring very close on my next attempt.
  4. BlackKnight12
    BlackKnight12 New Member
    Irvine,CA
    i had the same exact problem. if the fuel pump is turning over then its gotta be either your starter relay or fuel pump relay/fuse. this is under your seat. check the wiring on that. if your starter relay clicks then the fuse on that is probably busted. if it doesnt click, then its your circuit breaker/fuse to your fuel pump. im most sure its your starter relay fuse. should be incased in black rubber with a little green box attached to it. let me know if that works.
  5. BlackKnight12
    Irvine,CA
    if anything. check the small cheap parts first then lead up to your big expensive diagnostics for last
