Is there a problem driving a naked uncovered VFR800 ?
Discussion in 'Mechanics Garage' started by pzpz, Sep 13, 2016.
  1. tinkerinWstuff
    Put some dialectic grease in the connector and ride the thing. The plastic is for looks, not weatherproofing. The bike is designed to get wet.
  2. Badbilly
    But what if the dude wants to have one of those 175mph VFRs we keep hearing aboot? IMO, the plastic helps at least some...;)
  3. Hellapet
    Hellapet New Member
    Media, PA
    my only concern is that the fairings direct air through the radiators on the side of the bike and without them they may get heatsoaked.
  4. pzpz
    pzpz New Member
    Israel
    Has someone experienced riding the bike with no issues with wet connectors ?
    I Guess low resistance of wet connectors Causes current to flow in the circuits (short circuit).
    ( Impedance/resistance of tap water is almost 0 Ohm
    Distilled water is less than 25 Ohm
    Rain in a city polluted contaminated air... and other staff making ate water good conductor is in this range 0-25 Ohm.
  5. pzpz
    pzpz New Member
    Israel
    Thanks, but this does not seem to be a good idea : https://youtu.be/yuKAmaIkA-U.
    Although it will keep the water away, prevent short circuit of a wet terminal connectors.
    I t --- W i l l --- I n c r e a s e --- R e s i s t a n c e --- Inside the --- T e r m i n a l --- p i n s causing them to overheat and --- U n - C o n d u c t --- c u r r e n t !!!!
  6. pzpz
    pzpz New Member
    Israel
    - With side cowl off riding temperatures are just perfect !!! ( around 65 mph (6 gear : around 5000 RPM) on a 30-32 deg celsius day temps are less than 90 dec celsius, on the evening its 84 deg celsius )
    - On side stand it couls down in 60 sec 104->94 degs... (before with another coolant and cowls on it took more than 2 minutes).
    So air flow seems O.K.
  7. tinkerinWstuff
    Use the dielectric grease to keep moisture out. Same principle as the video link you provided, grease around the mating plastic surfaces.
    The VFR is prone to poor connections anyway. It's my belief that the fairings aren't going to make the difference one way or another.
    But the right windscreen will get you to 175mph
