informations about fork length.
Discussion in '1st & 2nd Generation 1983-1989' started by the tron, Dec 18, 2016.
  1. the tron
    the tron New Member
    hi everybody!
    i've got a question about the fork length of a vf750 interceptor.
    is there any one that can tell me how long it is, from the top of it, untill the center of the front wheel axle, please?
    cheers!
  2. JZH
    JZH New Member
    London, mostly
    Sorry, no idea. But, note that overall length could change slightly, depending on the length of the top-out spring (if any).
    Ciao,
  3. the tron
    the tron New Member
    thnks Jzh.
    it is just to have an idea of it.
    looking for a modern front end for my vf 750, knowing i don't have the vf fork, if i have this info, i'll be able to look for a fork that won't lower the bike so much.
  4. the tron
    the tron New Member
    nobody can help me?
    please!
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    What exactly are you trying to accomplish with this? Setting pre-load??
  6. the tron
    the tron New Member
    i was sure i wasn't clear, sorry...
    i need the length from the top of the fork cap, untill the center of the wheel axle.
    like if you have one "leg" of the fork on the bench, not fitted on the bike.
    i'm not sure to be clearer... :biggrin1::biggrin1::biggrin1::biggrin1::biggrin1:
  7. fink
    fink Member
    Is that the fully extended length with no weight on it ,or weight on it.
    Are you thinking of putting cbr forks on it?
  8. the tron
    the tron New Member
    YES!!! yes yes yes yes yes!
    fully extended length with no weight on it, exactly as you said, thank you!!!
    Are you thinking of putting cbr forks on it?[/QUOTE]
    maybe, or something else.
    and for my own cultur as well.
  9. 2Wheel Drift
    2Wheel Drift New Member
    Evansville, IN
    Here are a few forks for consideration if you want to change forks. I do not have the VF750 length for you. These measurements are from Thunderceptor: Fork lengths (measured from top of upper fork tube to center of axle)
    F2/F3 = 780 mm (30 3/4")
    F4/F4i = 750 mm (29 1/2")
    600RR = 730 mm (28 3/4")
    86 VFR 835mm
    YZF600R 805mm
  10. the tron
    the tron New Member
    thanks 2Wheel.
    i have read all of that already, and unfortunatly, the vf isn't in that list.
    my guess is that the fork of the vf might be pretty much the same length than the vfr.
    just need confirmation.
    but thanks again!!! ;)
    I thought I had a set of VF750F forks loose that I could measure, but I didn't. They are definitely much longer than 86 VFR750F forks. If I get a chance to roll the VF into the main shop I will jack the front up in the air and take a measurement.
  12. cknight
    cknight New Member
    Daytona Beach, FL
    My 1983 VF750F forks measure 34 1/2" from the top of the tube to the center of the axle with no load. Regards, Chase
  13. the tron
    the tron New Member
    thanks a lot Chase!
    that helps me out so much!
    and thanks to everybody for your help!!!
