I need a little bit of help from my friends..6th Gen mirror/windscreen inside covers
Discussion in '6th Generation 2002-2013' started by Keager, Sep 3, 2016.
  1. Keager
    Keager Member
    Would a 6th Gen owner be willing to pull out one screw and take a picture?
    What i need is the cover for the mirror bolts, below the windscreen. Just remove that *carefully* - don't pull out the rubber grommet like I did. That's why I'm in this predicament. One side completely fell off, the other side came out when I was looking at it to see what was going on.
    I've got a 2006, don't know if that makes any difference or not, but I would think all the 6th gens are the same.
    I've attached pictures of where I need help....
    [​IMG] [​IMG] [​IMG] [​IMG]
  2. 3.0charlie
    3.0charlie New Member
    Montreal, QC
    I can't make out what you are looking for, through reading your post and your pics.
  3. MrSleep
    MrSleep New Member
    Verdigris, Oklahoma
    which part(s) are you talking about?
  4. B6_Dolphin
    B6_Dolphin New Member
    My guess is #11 & #12 in the parts diagram.
  5. Keager
    Keager Member
    correct. under 11 & 12. what screw 21 goes into.
  6. 34468 Randy
    I am not totally sure what you were looking for here Keager, but I think the grommet you are referring to is actually a well nut. If you go to a Honda Parts counter and speak with someone lesser in the know, they are going to tell you they come with the cowl; fender or whatever they are inserted in. That is rubbish. It is a simple well nut available just about anywhere including Home Depot. You just need to know the correct size. I do think that the OEM does fit better than what you can get at Home Depot though. Once you have put them in, and set them by screwing in the screw firmly, they kinda crush around the hole in the plastic and will stay secure there. Problem with the aftermarket is they are a little thinner on the outside and tend to spin inside the hole in the plastic. This can be overcome but it is a bit of a nuisance.
    I suspect that it may be the exact same size as the other well nuts elsewhere on the fairings and cowls. This particular one looks like it may be mounted sop that you are inserting the screw or bolt backwards into the well nut.
    IMGP2192.jpg IMGP2193.jpg IMGP2194.jpg IMGP2195.jpg IMGP2196.jpg IMGP2197.jpg
  7. 34468 Randy
    Hmmmm. Looks like I have developed a crack in my plastics there. Oh well....nuts. I know, a groan-er.
  8. 34468 Randy
    I believe it is actually item #17 of that blow-up.
