Hurricane (CBR 600 F1) or F2 wheels on a wheel-swap?
Discussion in '1st & 2nd Generation 1983-1989' started by woody77, Jun 6, 2012.
  1. woody77
    woody77 New Member
    Palo Alto, CA
    From reading the wheel swap FAQ, the F1 wheel is a perfect swap up front, but is 2.5" instead of the more standard 3" of the F2.
    But what about the F1 rear? is it also a drop-in?
    I'm finding decent prices for both on ebay, and the prospect of not having to machine the front has my interesting. But.. Are the F1 wheels for radial tires, or bias-ply only?
  2. TOE CUTTER
    You really want to go with the complete F2 front end and F2 rear wheel.
  3. woody77
    woody77 New Member
    Palo Alto, CA
    A whole front-end would be nice, and isn't as expensive as I thought it would be. I'm seeing a bunch of front ends on eBay for about $250. I figure it would be ~$700 in parts and machine shop work to do a front end. Not sure I want to spend that much (on top of new tires).
    How much does the F2 front end lower the steering head? (and change rake/trail as a result?)
  4. artee
    artee New Member
    Rochdale,
    Buy a set of 1988/89 triples from Europe.
    Straight swap and 41mm fork size. Cbr600 fork size
    This is what I did to my 700, but I am in Europe.
    Maybe I should buy these bits for all you Statesiders, and ship them to you.
    Roger
  5. keny
    keny New Member
    Finland
    city of Hanko, Finland North Europe
    For the rear F1 wheel, not a straight swamp, BUT a European VFR750F 17" rear wheel is same looking and a straight fit to the 198-87 VFR700/750F. Also the first CBR1000F rear wheel might be a staright fit to the VFR, has same brake disc at least, and was last year (1989) 4.0 wide for some markets.
    I was also at time (when I had a 1987 VFR750F) making plans to fit a NC24 VFR400R 16" front rim (should be staringth fit as the CBR600F1) on my whit a CBR600F2 rear, but never did
  6. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Zombie thread alert
