How Much fork seal oil?
Discussion in 'Mechanics Garage' started by honda-maniac, Mar 18, 2010.
  1. honda-maniac
    honda-maniac New Member
    Danbury CT
    hi I m new to the forum, I have a 1986 honda VFR 700 that I owe for a year now and that I love.
    My fork seal need to be changed. Does anybody know the quantity of fork seal oil to dump?
    here a link to some pics of my bike
    Carlos Cordeiro's Photos | Facebook
  2. captb
    captb New Member
    When I did mine I used next heavier fork oil, mine work good for what they are.
    1986 vfr700 interceptor is .........370cc in the left fork and ...........358cc in the right
    Loosen fork caps while still mounted on bike
    Wash out internals thoroughly.
    Replace upper and lower fork bushings if they look like copper instead of medium grey.
    snap rings are reused unless mangled during removal.
    Clean seal and upper bushing area with solvent and green Scotchbrite pad.
    Coat all parts with fork oil b4 assembly.
    Use old seal on top of new seal to prevent damage during installation.
    Use 10 wt. FORK OIL, not the ATF recommended.
    Fill (with spring out) to 6" below top.
    A drop of locktite on bottom 6mm bolt is a thoughtful touch.
    Check your wheel bearings while it's off.
    1 1/2" PVC pipe and END CAP
    10 W FORK OIL
    SEALS DUST COVERS
    fork oil capacity:
    right: 358 ml or 153 mm from the top
    left: 370 ml or 153 mm from the top
    Rod Moran likes this.
  3. honda-maniac
    Danbury CT
    Thank you very much for al that info. it realy helps I not sure when I ll be doing it, soon hopefully.by the way your bike look very clean tumbs up =)
  4. squirrelman
    .....also be sure, after adding oil, to pump the forks fully up and down a few times to distribute oil, then fill to 6" below top.
    Some companies will sell you new seals at less than half Honda price, but they're not as good as OEM.
    It's very easy to mistakenly install seals upside down, so be sure any lettering ( size#s, manufacturer, etc.) is facing UP.
  5. Rod Moran
    Rod Moran New Member
    Southwestern Ontario
    im trying and failing to separate the inner tube from the outer fork sleeve so i can replace the seals and dust covers, any special teqniques you guys have used with success, I have been trying to pull them apart for hours and they haven't budged
  6. Rod Moran
    good info thanx
  7. squirrelman
    you might need some heat to get it apart.
  8. raYzerman
    raYzerman Member
    Millgrove, ON
    Have you got the clip out? You could be all day if you don't, lol. Heat is your friend if you do.
