How hot (water temp) should a 6th Gen VFR 800 get to?
Discussion in '6th Generation 2002-2013' started by BrooksyVFR, Mar 5, 2021.
  1. BrooksyVFR
    BrooksyVFR New Member
    is 116 deg C too hot after a run then sitting in traffic on a 16 deg C day?
  2. skimad4x4
    France
    French Alps & London
    Hi Brooksy and Welcome to the Madhouse
    The short answer to your question is yes these things run hot - and they get really hot at times when stuck in traffic. Sadly side mounted radiators are not brilliant at dissapating heat when stationary.
    At that temperature you should be able to hear the radiator fan running? If it is not running you have a problem which needs attention.
    When you get time please swing by the "introductions" part of the forum and say Hi to the rest of folks on here.
    Take Care ATGATT
    SkiMad
    BrooksyVFR likes this.
  3. BikerSte
    BikerSte New Member
    Ireland
    I fitted a switch so I can turn on the fan in traffic or anytime I want. The fan still turns on by itself when the temperature gets high. This was my solution to our problem.
  4. Diving Pete
    116c is still within 'normal' operating range - although at the top of it. I personally would be turning my engine off at 120c - although Honda say 128c I think.
    Mine normally runs at 78c & in traffic I sometimes see 106c. The fan comes on at about 102c from memory.
