Honda VFR 750 RC24 89 Won't start noise on the starter Relay
Discussion in '1st & 2nd Generation 1983-1989' started by VfrGohu, Nov 25, 2019.
  1. VfrGohu
    VfrGohu New Member
    France
    Hello Everyone,
    I'm riding this bike everyday since one year and the last week, I was not able to turn it on with the starter button.
    If I push the bike with the second gear on, it will start straight away.
    The battery have been charged.
    And when I push the starter button, I have a clac-clac-clac on the starter Relay, do you confirm I have only this to change them?
    Thank you for your help.
  2. sixdog
    Battery may have voltage but not enough amperage. Have the battery checked and or replace it.....
  3. VfrGohu
    VfrGohu New Member
    France
    Thank you!
    The clac-clac from the starter relay doesn't say that the Relay is dead?
    Can I put some gel Battery?
  4. Diving Pete
    That noise usually means that it needs more amps! Easy way to check is with a pair of jump leads on a working car battery (WITH THE CAR ENGINE NOT RUNNING).
  5. VfrGohu
    VfrGohu New Member
    France
    Alright thank you!
    Yeah I just learn that today while reading the forum!!!
    Do you have any clue for the gel battery?
  6. Diving Pete
    There are various options for you - not sure any are honestly better than others - although most of my batteries are Yuasa.
    Motorcycle batteries are 'pretty on the edge' & so worrying too much about it is pretty pointless - if they last more than a couple of years I'm happy.
  7. Terry Smith
    New Zealand
    The rattling sound comes from the starter solenoid: You press the button, the solenoid is magnetised and the contacts close to feed current to the starter motor. The current draw is too much for a sick battery to sustain so the voltage drops and the solenoid opens. That allows the voltage for the battery to "catch-up" so it can magnetise the solenoid closed again. And repeat...
  8. VfrGohu
    VfrGohu New Member
    France
    Thank you for the explanation!
  9. VfrGohu
    VfrGohu New Member
    France
    Battery swapped and it's running well. Thank you all.
    I bought a battery ACID without the possibility to fill it up.
    The polarity wasn't the same but it fit as well.
