Help with 86 CARBS going on 87 VFR 700
Discussion in 'Mechanics Garage' started by bf519, Sep 22, 2011.
  1. bf519
    bf519 New Member
    Texas
    Can someone tell me a setting for the Pilot jets for a 87 vfr700. I'm installing a set of 86 California CARBS with out the canister set up. I sealed the recovery tubes. I live at sea level. Shop man states to start with 2 1/2 turns out and adjust accordingly. I don't have the CARBS synced yet so I need to start with a pilot jet setting that should be close for starting up the bike. As we know how much fun it is to install and remove these CARBS I'm hoping with your help I won't be working on the CARBS again any time soon THANK YOU
  2. bf519
    bf519 New Member
    Texas
    Im also using a K&N air filter on the bike.
  3. Railguy
    Railguy New Member
    New Mexico
    2 1/2 will be fine for a baseline, then you need a accurate tach and do the idle drop procedure ,,thats usually pretty darn close
  4. squirrelman
    ^^^^What he said.
