help! bike wont start
Discussion in '1st & 2nd Generation 1983-1989' started by marcsvf500f, Mar 26, 2009.
  1. volks6000
    volks6000 New Member
    Jacksonville , Florida
    your battery and starter both work, then your have a bad soleniod or a bad switch . use a meter and a manual go by what it says to do to test them. this way you can find out which is bad. then replace the bad part and your back on the road. get soleniod off E-Bay it will match up, remember you have 4 wires that hook to that thing. good luck.
  2. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
    But with that your light should die when you try to start.There is something take allot of power or short curcuit in the wires harness or in some device.
    Best regards
    Gunnar
