Fuelling Issue?? Idle + VTECH - A bunch of weird things
Discussion in 'Mechanics Garage' started by Hamza, May 30, 2026 at 3:50 AM.
  1. Hamza
    Hamza New Member
    Hi guys,
    Have been browsing the forum for some useful information; found some tips but nothing that mimics my experience;
    I have a 2012 with 96,000 kms, down in Melbourne, Australia.
    Recently did an oil change, brake bleed some standard TLC got the injectors serviced. I had not changed the fuel filter in a few years so took the opportunity to do this also with an OEM fuel filter. I have also ordered a new hot idle wax unit as I think mine has been shot; on Occassion it does not idle consistently, a few months ago a mechanic messed with it and turned the adjustment nut a few turns...go figure...
    Once I reassembled everything, the bike started falling over itself and sputtering badly around 6,500 -6,800 RPM's. (Side note: I will admit, the reassembly of the fuel pump assembly into the tank after the filter fitment was a bit tricky and I was not sure if shoving the last bit of the steel wool filter was the way to go but I could not get it to fit otherwise..). Because I had fit in a new filter, I suspected perhaps an incorrect assembly causing fuel delivery restrictions?
    To avoid draining the tank, I thought I would have a look at the vacuum hoses to make sure there were no vacuum leaks - sure enough found the vacuum hose for the flapper valve off the intake nipple. (Should mention that the bike has had the snorkel delete, flapper mod + PAIR delete (blocked off) for a while and it was running great). Took the time to redo all the vacuum hoses with fresh silicone hoses; MAP + FPR circuits. Blocked off the flapper valve hose with an end cap so no vacuum leaks now!
    After this, the power all the way through VTECH to red line seems much much better, doesn't stumble but it does occasionally hesitate between 6,500 - 8,000..almost stutters through the revs all the way to redline..Gut feeling is that it feels like a fuelling issue at this time to me...
    A few other mystery items; After the bike is warmed up, I can smell what seems to be a rich exhaust... (i have a REMUS exhaust system on it (just the cans and piping from the collector)
    Also the left side exhaust (standing behind the bike) feels warmer than the right side?? I tried to read up on how the collector box is made but on the face of it looks as though it is a 4 into 1 and then into 2 for the cans?
    I am thinking before pulling out the fuel pump again, my FPR may be malfunctioning?
    I could not smell any fuel or see any visible fuel leak out during priming with just the ignition ON? Could it be just stuck shut?
    Did a starter valve sync and got a solid steady adjustment 8-9 inch of vacuum.
    I really appreciate you guys helping out...really doing my head in..
    Thumbs likes this.
  2. RllwJoe
    RllwJoe Member
    Are all of the vacuum values soposed to be identical for the 6th gen?
    I own a '98 (5th gen) and the FSM states they are not!
  3. Hamza
    Hamza New Member
    Hey RillwJoe,
    Yeah..they are all referenced to cylinder 4, I set up the gauges so the one on the left is cylinder 1 and the one on the extreme right is cylinder 4.
  4. Thumbs
    Thumbs Member
    Bath(ish)
    Get an infrared temperature gauge, they so cheap and so handy
