Dyno run resultls for '99 VFR
Discussion in '5th Generation 1998-2001' started by Joey_Dude, Jun 30, 2009.
  1. soundmaster31
    soundmaster31 New Member
    Jackson, Michigan
    Closed loop systems(most vehicles today) rely on an Oxygen sensor(lamda) to compare oxygen levels in exhaust gases to those outside of the system. They're mostly based on lowering emissions and improving fuel economy. The oxygen sensor tells the EFI how much oxygen is available for combustion and doesn't let the engine run rich. Some systems will start up in open loop mode then switch to closed loop once the engine is warm.
    Open loop doesn't rely on an Oxygen sensor.
    I thought the SAE methods were for whether they measured torque or hp to calculate the other one. :confused:
