Did some painting and pin stripes on my 86' 700.. Tell me what you think
Discussion in '1st & 2nd Generation 1983-1989' started by Hey its me, Feb 14, 2014.
  1. flash50080
    flash50080 New Member
    Lebec,CA USA
    red , why did you not fallow the body line with the lower one? not that it looks bad just not normal way to pin stripe
  2. flash50080
    Lebec,CA USA
    what rims are on there and what mods would i have to run to do that? i need the bigger side rubber i have my bike on the feather edge of my tires and am concerned one time i will over do it. sorry to hijack the thread
  3. Hey its me
    Hey its me New Member
    Seattle, WA
    Wow, I wasn't expecting so much love for the red pin stripes. Thanks for the input.
    flash- It looks bad because it was my first time I've tried pin striping. Im just experimenting before I paint the whole thing.
    Mods are: CBR Rear F-3 wheel, re-welded brake caliper holder. Shaved reaction rod. CBR Front F-2 wheel. I think the forks are CBR, and the upper triple is from a 94 VFR. Ill have to double check on that. I bought it like this, btw.
  4. flash50080
    Lebec,CA USA
    it dose not look bad it was just a question its allways good to experiment first. cool thanks i need to do that they look good to, let me know when you find out
  5. Badbilly
    For experimental pinstriping using vinyl tape. It is less costly to use regular masking tape to create or define a line. The masking tape is easily removable and adheres to wax of the natural and polymer types.
    I would not advise using any type tape over that plastic dipp stuff that is really for the handles of oyster forks and South of the border socket sets.
    Once the line or design is established. The better choice of the vinyl "striping" tape is by 3M. All wax should be removed prior to application of the vinyl tape to insure adhesion.
    Best done in both apps when nice and warm to allow for curves without wrinkles and again adhesion.
    Crossed lines and butt joints can be double cut for neatness. See any Utube vid for doublecutting under wall covering or paperhanging.
    Nice neat 90 degree end cuts can be accomplished by lining up a single edge razor blade and pulling the tape end across the angle of the blade.
    Real pinstriping is a whole different thing.
    No, I am not kin to Von Dutch or Ed Roth.
