Check Your Nuts!!!
Discussion in 'General VFR Discussions' started by Lint, Mar 30, 2018.
  1. Lint
    Lint Member
    Simi Valley, Ca.
    Well, today was productive! New tires, new rear brake pads, I will be ordering a new rear rotor and I had the thought to check the swingarm nut, since the engine has an increase in vibration. I had already checked the others. The nut was loose.
    A big thank you to OOTV who not only gave me the torque spec, but he also told me where to look in the service manual!
    Swingarm pivot nut is 69 ft.lb
    Section 1, 1-17 of the pdf
    Also in section 14. Exploded view is on 14-0
    Bubba Utah and OOTV like this.
  2. A.M
    A.M Moderator Staff Member
    Wow! Good catch right there. How often should these be inspected? If any? Obviously yours was loose, but is this common? What is the torque spec?
    Bubba Utah likes this.
  3. ducnut
    ducnut New Member
    Excellent reminder.
    I had a Daytona 675 track bike that regularly loosened the same engine bolt. Like you, I found it through a change in engine harmonics. Checking all the engine mounts became part of my oil change routine, on that bike.
    Thursday, I pulled my SV’s suspension and found a loose shock bolt. That’s something I’m going to add to the oil changes on that bike.
    Bubba Utah and Lint like this.
  4. Lint
    Lint Member
    Simi Valley, Ca.
    Torque specs are above. I have no idea if it's common, but my bike took a big hit when I crashed at the end of December.
  5. Bubba Utah
    Bubba Utah Member
    Utah
    I MISS MY SV! :Mad2: that V-twin vibration and torque will do it to all the bits and pieces.
  6. Bubba Utah
    Bubba Utah Member
    Utah
  7. duccmann
    While you were at it, did yah throw the wrench on that red shiny beastly next to your bike Mr?
    Lint likes this.
