Carby Insulators for 2nd Gen
Discussion in '1st & 2nd Generation 1983-1989' started by Sells, Jul 9, 2016.
  1. Sells
    Sells New Member
    Karratha, Western Australia
    Hi guys, I am restoring a 1989 VFR750 FK (Australian version) and am unable to locate the carby insulators (16211-ML7-891) which I want to replace. It is listed as a discontinued part everywhere I've seen. Does anyone have any thoughts as to alternatives/solution? Does anyone know if different carb insulators can be substituted?
    Cheers :)
  2. Allyance
    Allyance Insider
    East Bay, California
    Partzilla doesn't even list the 1989 VFR750, however, they have the insulators for a 1990. Do these look like yours?
  3. Sells
    Sells New Member
    They look similar, as do some other part no's, but I'm not sure if the diameters/other dimensions are the same
  4. Tedric
    Tedric New Member
    Derbyshire. UK
    Hello mate, I think you will find that the inlet rubbers from an Honda VFR 750 FG or the VFR 700 USA version (part no.16211-ML7-000) will fit they have exactly the same dimensions.
    Ive got a set of Fk carbs in my garage and the rubbers are exactly the same as my FG.
    These are readily available try David Silver Spares or NRP Carbs both are based inn the Uk
  5. squirrelman
    As i've seen a few times, there are non-OEM mounts on the market now that don't have the "CARB" slot but seem to work OK.
  6. Sells
    Sells New Member
    Thanks guys, I'll check it out. I am following up a 'dead stock' lead in Queensland, but this will make it much easier :)
