Brake Discs
Discussion in '6th Generation 2002-2013' started by gordyp, Aug 31, 2018.
  1. gordyp
    gordyp New Member
    Just about to replace pads front and rear on my 2007 30,000 mile baby. Discs have a bit of wear, bit of a lip round the edge. At what stage of wear would you replace??
  2. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    When they are 3.5mm or less, or badly scored.
    gordyp likes this.
  3. gordyp
    gordyp New Member
    Thanks, think I’ll bite the bullet and just do them at the same time. Fact I’m even worrying about it probably makes it worthwhile!
    Oooft, 400 quid......
  4. OOTV
    OOTV Member
    I was just about to add that there is a sticker shock associated with brake rotors but looks like you discovered that! There are after market rotors that are good alternatives but the cost isn’t that much less and sometimes even a bit more than OEM. Although cheaper, there are Chinese versions on eBay and other online outlets, I personally have not tried them, too chicken to take a chance to see if the Chinese quality is actually less as many claim. Two places to not take chances with quality, brakes and tires! I’m sure there are many instances where someone has used them without incident so just be cognizant of that and caveat emptor.
  5. gordyp
    gordyp New Member
    Ordered the OEM discs and pads, as you say brakes and tyres are the important things connecting us to Earth! Be happy to get another 30,000 Miles out of this set.
  6. gordyp
    gordyp New Member
    New front and rear discs arrived along with a set of new rear pads and like the total asshole that I am ONE set of front discs....
    I’m an idiot
  7. OOTV
    OOTV Member
    Assume you meant one set of front "pads". The last time I bought pads online, the web page had a note to remind me that if buying front pads, I might need two sets. At one time though, the VFR had the same pads for all calipers. I think the 06+ is where the fronts are different.
