Bike shuts down while riding, what could it be?
Discussion in 'Mechanics Garage' started by Petito, Aug 13, 2015.
  1. EpiEric
    EpiEric New Member
    Netherlands
    Lingewaard, The Netherlands
    This has to be the cause.
    Meantime you cleaned all connectors. It has to be ok for a long time. I'm pretty sure too..
    Verzonden vanaf mijn iPhone met Tapatalk
    #41
  2. NormK
    NormK New Member
    But have you removed the stator/rec/reg connector, if not that will be the next one to catch you out
    #42
  3. Petito
    Petito New Member
    Quebec City, QC
    God......
    it did it again today, my bike is curseddd!
    Could you guide me on that NormK please? I'm not really familiar with this connector.
    #43
  4. EpiEric
    EpiEric New Member
    Netherlands
    Remove the connector from the R/R and solder the wiring.
    #44
  5. EpiEric
    EpiEric New Member
    Netherlands
    But i don't think that's the actual problem. As you describe it .....imho the kill switch or the side standaard is the main problem.
    #45
  6. Petito
    Petito New Member
    Quebec City, QC
    That's what I think too...
    Maybe I should try replacing the side stand sensor? It's about 60 bucks.
    #46
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Number one, the RR to stator connection will fail eventually, so just do it. Number two, I still think you have a bad main fuse holder and or big blue connection. Number three, to humor you and fully diagnosed the problem, just disconnect the side stand switch and bridge it, to rule it out of the equation.
    Sent from my A0001 using Tapatalk
    #47
  8. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Cutting out the main fuse holder and replacing it with a higher quality unit, replacing the RR with a FH020AA and direct soldering it, as well as bridging the grounds in the big blue connector are just things that should be done to the VFR as soon as you buy it. So just do them now while you're trying to find out what's wrong.
    #48
  9. Petito
    Petito New Member
    Quebec City, QC
    I guess I'll do all of this during the winter, is it a hard job to get through?
    #49
  10. EpiEric
    EpiEric New Member
    Netherlands
    No. It's not a hard job. Just takes some time and patience.
    For starters....... Stll I recommend to bridge the sidestand sensor. For me it's the prime suspect.
    #50
  11. NormK
    NormK New Member
    It is a process of elimination, only you can do it, we can give advice but that is all. As said, bypass the sidestand switch, then you may have to bypass the kill switch. This shutting down isn't related to moving the handelbars?
    #51
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Oh another problem I had like this, my connection between the ignition key witch and main harness. It had burnt up. I had to cut it out an direct solder it.
    This isn't very common, but its worth checking.
    #52
  13. Petito
    Petito New Member
    Quebec City, QC
    Alright, I will bypass the side stand sensor, and then I will check the connector between the main harmess and the ingnition key switch.
    #53
  14. EpiEric
    EpiEric New Member
    Netherlands
    Don't forget the kill switch. More likely than the connector between the main harness and ignition key......
    #54
  15. EpiEric
    EpiEric New Member
    Netherlands
    Any News ??
    #55
  16. Petito
    Petito New Member
    Quebec City, QC
    Bringing back a very old post, sorry for being this late!
    I finally fixed my problem, it was related to some wierd looking fuses, I don't have pictures, but the fuses "teeth" were not parallel at all. the teeth end were almost touching...
    Put new fuses in and everything ran just fine!
    #56
  17. jpfvita
    jpfvita New Member
    Not sure if anyone has said this yet but check the side stand relay and or spring.
    My RF 900 Would cut out and ended up being the spring had became weak and over the right size bump would cut her out, lol
    Don't forget check relay. !!
    #57
