Attempting to bring back a VFR that was left for dead.
Discussion in '5th Generation 1998-2001' started by dallasca, Jan 1, 2014.
  1. dallasca
    dallasca New Member
    I got a screaming deal on the entire LED tail/brake/indicator unit $20 so thats what I'm using. I had to attach a perch tab on it from my old tail light but a dremel made it a easy task. No cracks just 2 broken tabs. 1 isnt that important but Ill prolly fix it the same way just tobe safe
  2. dallasca
    dallasca New Member
    Great news I guess.. Well it depends on how you look at I was just informed that we are not working Sunday. or next weekend so I can get the vfr on the road. The bad no extra work means no extra money for parts, wich have been stacking up.. Cant wait to get going on it again
  3. dallasca
    dallasca New Member
    Update from this weekend. I did the brakes all the way around. And yes the Pad pin was a major PITA. The cap came rite off it was the pin that was stuck. So bad in fact that I twisted a Snap-on Hex socket slightly before it finally broke loose. Well when I put on the rear wheel I noticed what looks like a fiberglass pad that looks like it could be some type of spacer under the bike. I looked a Bike Bandit and this piece doesn’t seem to be part of the brake caliper set up "No picture of it shown" Nor does the service manual show it. Is this a piece of a old pad that just came apart? I couldn’t see were it would have come from, or does it belong somewhere in the caliper.
    There was also only 1 of these it has the same markings on the other side as pictured.
    Thanks for any help
    Pics up soon of the work so far
  4. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    It goes behind the brake pad as a buffer between the metal of the pad back and the metal of the caliper. It keeps the brakes from squealing.
  5. dallasca
    dallasca New Member
    Thank you. which side of the caliper, swing arm side or open side? there is nothing anywere saying were it goes.
  6. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    Since you only have one I would put it on the piston side of the caliper. On a dual piston caliper it probably doesn't matter. I have not been into my brakes yet so I can't say for sure.
  7. dallasca
    dallasca New Member
    Ok thank you. Have u thought about going on our ride? Its the middle of the week so only a few r going to make it..txt me so I can get u the details. I pmd u my cell
  8. Big_Jim59
    Big_Jim59 Member
    Dallas, TX
    I sent you my cell. You can txt me details.
  9. Bowidog
    Bowidog New Member
    Hey this is a great thread, thanks for the photo's too. You must have the patience of a Saint!
  10. dallasca
    dallasca New Member
    Thank you. My wife says I "Have something" lol Im uploaded pictures in the next few min of her almost street worthy
  11. dallasca
    dallasca New Member
    What a better way to start a new page than post PICTURES
    Getting ready for who knows what... oh may as well do brakes since they came in..
    Looks better but still ruff. I left the red over spray on the sub frame for now. Tryin to figure out how to remove it with the least amount of elbow grease.. Ya I know good luck..
    Yellow over spray on the fork tube! I gave up tryin to figure out how some of this paint ended up were it did.. This color yellow isnt on the bike other than there..Had to strip all the oversprayed/brushed on pain off. At least I have nice clean surfaces to work with/ Yellow came rite off w a little thinner.. So thats what I'll do with the red on the frame.
  12. dallasca
    dallasca New Member
    More pics this time some finished for now pictures
    Had Plasti diped the tank. The tape is from me coating the clutch cover with some RTV Hi temp flat black. I was not sure if I would have to replace the gasket aand didnt have a spare so I taped it all off and did it on the bike.
    Filler spout painted same as the Clutch cover. Getting ready to hit the upper tripple with "yes you guessed it Plasti-dip"
    Inners, Guage trim, and upper tripple Plasti-diped black. Remember this plasti dip can be pealed off when Im tired of it.. Thats why I use it. and it covers ugly pretty good wouldnt you say? New Levers are on the way also.
  13. dallasca
    dallasca New Member
    Here we go Reasemble
    Fender, Tank, and left fairing "remember the left was the one with the hole and all the cracks in it.. turned out way better than I had hoped..
    Need to Plasti-dip the tail, and left fairing. Thinking about doing the wheels also. I had to make a fairing mount and adjust the other to get the proper line up. Still need to get that over spray off the radiatiors and sub frame.
  14. Destroyer
    Destroyer New Member
    South Africa
    Sheez!
    That looks excellent, man!
    Well done!!!
  15. dallasca
    dallasca New Member
    Thank you. while I'm on here anyone know what they call the screen/mess that these guys are putting on the back side of there fairings over the air flow holes?
  16. Mohawk
    Mohawk New Member
    Bristol
    Tail lights are 5W x2 =10Watt so very little. Stop lights are 25W x2 =50W but as they are intermittent load, they don't really count. LED everything else will not bring down the load enough to let you run 90W dip lights, not to mention you will fry the harness unless you use a relay & appropriately sized direct wiring to carry that lighting load.
  17. dallasca
    dallasca New Member
    Thank you for the info. I'm gonna do some upgrades to the wiring as well as a couple of other tricks a few other forum members have suggested.
  18. Bowidog
    Bowidog New Member
    Stealth VFR - Incredible!
  19. dallasca
    dallasca New Member
    Nice catch F-117 lol tring to find USAF decals to do a stealth replica type theme till I go and paint it later on..
    Uploading more pics as Im writing this post..
  20. dallasca
    dallasca New Member
    Old sprocket vrs new sprocket compairison
    Everything in black sharpi "not the arrow lol" was tobe cut off to make a 1 up bike. Decided to wait for now
    After Plasti-dip
    What the rear sprocket and chain looked like when I got it
    After chain and sprocket replacement
