any ideas??
Discussion in 'USA - West' started by 85vf500rider_MattMan, Jul 24, 2009.
  1. 85vf500rider_MattMan
    85vf500rider_MattMan New Member
    i have an 85 vf 500 intercepter with a few issues. first, it will not idle with the choke off. the only way i can get the bike to start is to crank the choke all the way open, turn the bike on, and ease the choke about 1/4 closed, any less and it dies. im sure this next problem is related in every way but the bike idles extremely high to, about 3500 and when i gas it to go, the bike bogs down and about half the time dies. thats the biggest issue i have with the bike right now. any ideas on how to fix?? i thought about getting aftermarket carbs though i dont have the money for them so im pretty stuck.
  2. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    Clean your carbs and check the boots for cracks before buying new ones.
    -Jake
  3. 85vf500rider_MattMan
    cool. will do!
  4. PyroMcnoob
    PyroMcnoob New Member
    Riverside, CA
    yup, clean the carbs... sometimes gunk builds up, especially if the bike sat for any length of time... mine ran like crap til I did that, now it's a monster :D
  5. cdesousa89
    cdesousa89 New Member
    Bay Area, CA
    I have been looking high and low.
    I just purchased my 85 vf500 yesterday and it has the exact same problem. I put some sea foam in it but didnt help too much. Did cleaning the carbs fix it?
  6. volks6000
    volks6000 New Member
    Jacksonville , Florida
    if the bike won't idle or bogs then it's carb cleaning time. take each carb apart 1 at a time, so you don't mix the parts up. don't seperate them from the top. lot of carb cleaner and air. when your done the bike should fire up without the choke and should idle about 1000 +- 100. good luck let us know how it's going. seafoam is used for light cleaning.
