Airhawk R seat cushion.
Discussion in 'Gear & Accessories' started by V4toTour, Aug 10, 2014.
  1. V4toTour
    V4toTour New Member
    Looks a bit goofy strapped to the VFR seat, but the results are amazing. 12 hours of seat time yesterday and no squirming around trying to relieve numbness and pain. Usually after about 3 hours I start standing up on the pegs every 10 mins or so. For those not familiar with the Airhawk, features built in grundle cooling by way off mesh sides that allow air to pass through and underneath your posterior helping reduce swamp ass on those summer rides. The R version has a center channel of nothing designed to provide room for man parts, unlike the standard one. Also works as a really effective shock absorber, bumps in the road that might otherwise tweak the jewels and give you a bit of a tummy ache are effectively reduced.
    Totally recommend trying one out before dropping coin on a Sargent seat or similar that may or may not work.
  2. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Can we get a pic please? Do you feel that it alters the riding position much?
  3. V4toTour
    V4toTour New Member
    Not at all, in fact the company says that if you need to adjust your mirrors you've over inflated it. It might feel a bit weird at first, you can feel the air move from chamber to chamber underneath you almost like sitting on a tiny water bed.
    Basically fill it up, place it on the bike and crack the air valve until you sink down. Proper level is just above the stock seat, if you feel yourself sinking into the seat below you've let out too much air. The amount of air needed is actually very minimal. I'd say half inflated or less is ideal.
  4. Vfourer
    Vfourer New Member
    Southerner
    Did a 14 hour day, then two 10 hour days using a Airhawk and didnt get sore once and felt refreshed at the end of every day, a must have for long trips.:thumbsup:
    MARTICUS likes this.
  5. MARTICUS
    MARTICUS New Member
    VA
    Sorry for bringing back an old thread, I'm about to order these. I was looking at the cruiser small and duals port sizes, but your still happy with your "r"? Does the bladder hanging off the sides of the seat (just a little in your pic) ever become an issue?
    Thanks!
  6. V4toTour
    V4toTour New Member
    it does hang out the sides a bit, but that hasn't been an issue. I used the R on a cross country ride recently, was a life saver. The point of the R is it has an empty channel down the center that leaves room for your "stuff". The other airhawk products do not. However if you are looking for a smaller profile seat pad with that channel, freedom air sells one. Their sport touring model. When my airhawk dies, I'll most likely order the freedom air one.
    http://www.longeride.com/Products.html
  7. MARTICUS
    MARTICUS New Member
    VA
    Thanks man! From the looking I just did I can't figure if I'll be able to get a freedom air sport for my trip tuesday. It does look ideal though. Thanks for the feedback though! I'm going to order the r from zilla and I'll have it by Tuesday shipped from their Philly location. Hope it keeps my bunns happy B^D
  8. V4toTour
    V4toTour New Member
    remember though, the less air the better when using these. half inflated or less. fill it up, sit on the pad and slowly crack the valve to bleed out air. sink down until your comfortable. You should just be up off the stock seat. you don't want to feel like your sitting on a pool raft.
  9. MARTICUS
    MARTICUS New Member
    VA
    Yeah I've heard a lot of people say they're very uncomfortable when over inflated. At hour 4 my "*Ischial Tuberosities" bones were going to climb out of my arse and run away.. this looks like a good system :) maybe even keep it cooler down there!
