93 "crack, snap and pop"
Discussion in '3rd & 4th Generation 1990-1997' started by dinenoj, Dec 6, 2009.
  1. dinenoj
    dinenoj New Member
    Found a '96 motor, picking it up later this week.
    Will let you guys know what I find when I open the other one up (with pics).
    Once again thanks for the input.
  2. dinenoj
    dinenoj New Member
    The rebuild/ motor swap is complete!!!
    All went well, and rides perfectly other than I need to do a carb sync and adjustment.
    A '96 motor being put into a '93 VFR is not an exact match/ swap, but no big deal, took two days to complete.
    Thanks to all for assistance.
  3. Jimtt
    Jimtt New Member
    Chicago area
    Good job, you should have no trouble now.
  4. dcompson
    dcompson New Member
    How does the bike run now? Did everything go well?
  5. dinenoj
    dinenoj New Member
    Thanks for asking, she runs quite well although she failed the emissions testing here in AZ. Bad Hydrocarbon reading so I think a vacuum leak or electronic.
    I did put the '93 pulse generator into the '96 motor (plug was reversed from the '93 wiring harness) and left the '96 Stator (generator (coiled wire inside spinning flywheel)) on the '96 motor even though all the rest of the electronics is the original ,93 components.
    Excellent running and handling bike, I forgot how nice this bike was the day I bought back in '93.
  6. dcompson
    dcompson New Member
    Great looking bike! Mine looks like that, but much older and used. Did you take the 'vfr' stickers off of the mid farings? I like the look, kinda cleaned it up a bit. Also, emissions !!!!??? WTH!!! On a bike? That blows! In AZ you can register cars and bikes so easy and for so long.... I am just floored by the fact you have to smog them. Any ideas how you are going to fix the failed smog?
    Also, if you are ever out this way, Vegas, drop me a line.
  7. Fazer1Sniper
    Fazer1Sniper New Member
    Looks fantastic, good luck on the smog issue.
  8. dinenoj
    dinenoj New Member
    dcompson- yeah, the day I bought the bike back in 1993 I pulled out a can of Bestine and removed the mid fairing stickers..... not really sure why but must have made sense at the time.
    Down hear in AZ a law has been passed to eliminate emissions on motorcycles but has yet to be approved by the feds(EPA), possibly sometime this summer. But I want to get her registered for this spring......actually Now because it's very nice out (77deg).
    I may be pulling the carburetors off again and check everything to out. Something must be plugged because while trying to adjust the pilot jet screws only the left side carbs effect the idle. On the right two carburetors whether the screws are all the way in or all the way out, no effect at all to the engine speed.
  9. deepdish
    deepdish Banned
    starter hanging up check your button and make sure it is springing back all the way..had an ole hurricane did that spring was bad..
