4th Gen (VFR 750 f-T 1996) Front fork swap
Discussion in '3rd & 4th Generation 1990-1997' started by thewyndonarms, Sep 19, 2012.
  1. thewyndonarms
    thewyndonarms New Member
    Hi all,
    Winter approaching and i'm looking to spend some time sorting the bike.
    A few jobs need doing including the front end. I want to put a set of USD forks on it but I'm concerned about matching the front wheel and possibly calipers.
    I dont mind changing calipers too but still want to keep the front wheel.
    Has anyone done this conversion? I've heard a Fireblade is a near swap.
  2. REEK
    REEK New Member
    Sacramento CA
    i dont think theres an easy swap that keeps the original front wheel. usually takes some machining for spacer or axle issues. cbr 929 or 954 front ends are easy direct swaps but you have to use the complete fronts. rims wont match but there are other benefits that make it worthwhile
  3. thewyndonarms
    Thanks for that. Sorry if this sounds naeve but if I change the whole thing, will I be able to keep top and bottom yokes or will they need changing too?
  4. Marley Davidson
    Marley Davidson New Member
    Matosinhos, Oporto
    You have to change both yokes because the diameter is not the same...use the 929/954 yokes.
