1996 VFR750F Questions/Help...
Discussion in 'General VFR Discussions' started by salaero, Mar 19, 2009.
  1. salaero
    salaero New Member
    Hey,
    New to VFR's but have always loved the bikes. Can anyone give opinions on the 1996 model VFR? I am looking at picking up a used one with 28000kms on it. I have read that these engines are pretty bullet proof and go forever. Anything I should look out for etc before buying it?
    Thanks for any info.
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    The 4th Generation bike is the last of the carbureted bikes. It is often referred to as the "high water mark" of the VFR lineage (no bias here...:rolleyes:), and has won many awards in the motorcycling realm.
    28,000 km is next to nothing on these bikes, some would say that you're still 28k shy of your first valve check (you may not even need to adjust them).
    The regulator/rectifier is the only weak point on these bikes, everything else is pretty much solid.
  3. squirrelman
    Seeing service records would be nice, but this is one of the best VFRs EVER (lots of bias here), so just have a thorough test ride, and make your deal !!
    IF you can do whatever minor service it might need, you're golden! Enjoy.
  4. Yakima9
    Yakima9 New Member
    Wausau, WI
    I love my '96. Lube the chain, change the oil, and ride. The R/R is pretty much its only weak point.
  5. MarkBartels
    MarkBartels New Member
    The best of course is the 4th (94-97) generation VFR!:smile:
    They are all good, I just happen to be biased. Make sure it has been maintained properly and enjoy!
  6. STEVE MANKIN
    STEVE MANKIN New Member
    ft. myers fl
    best of the best...if it looks good and runs well ..buy it...i still love mine after 13 years of ownership...
